drag in 4wd
Old Mar 28, 2005 | 09:05 AM
ksig4runner's Avatar
drag in 4wd
so the other day i went out and when i put my 4runner in 4wd there was some drag on the passenger side and it was pulling to the right. i took it out of 4wd and nothing. what is going on here
Old Mar 28, 2005 | 09:22 AM
mt_goat's Avatar
Were you trying to turn on dry pavement?
Old Mar 28, 2005 | 07:51 PM
no. goin straight down the road engaged in 4 hi it was pulling to the right. Is this an axle problem or something in the hub or what?? im totally lost here
Old Mar 28, 2005 | 08:19 PM
kyle_22r's Avatar
don't use 4wd on the road.
Old Mar 29, 2005 | 04:30 AM
mt_goat's Avatar
It shouldn't do that, I sometimes pop mine in 4WD on the road (straight line only) just to keep the CVs lubed and it never pulls or drags. I'm at a loss to think of what would cause it. The first thing I'd do is unlock the hubs and crawl under the truck and start tuning the CVs by hand to see if they turn freely and smooth.
Old Mar 29, 2005 | 04:42 AM
mt_goat's Avatar
Just thought of one thing that would cause that, if one tire is a different size than the others it will cause binding in 4WD.
Old Mar 29, 2005 | 04:55 AM
mt_goat's Avatar
If the gears in the front diff are a different ratio than the gears in the rear diff there will be a lot of drag in 4WD, but in 2WD it will be fine. Some history of your truck may help.
Old Mar 29, 2005 | 12:17 PM
mastacox's Avatar
It might do that if one of your sides isn't engaged... I have done that before but I have manual hubs... Pulling to the right seems to suggest only your front left is engaged. It could be your ADD system for your front diff didn't engage your front completely
Old Mar 29, 2005 | 12:22 PM
mastacox's Avatar
Funny you would say that, I actually had that problem when I exploded by front diff. The first replacement I bought from a wrecked T100 was actually in worse shape than my original (entire ring gear pretty much ground flat ), and then I bought a replacement from a junk yard that was supposedly 4.30, when in fact it was 4.56. This led to some major underspinning of my front tires, it looked like I was trying to brake stand I finally got a good diff (decided to just dump the ADD) and now everything is happy.
Yeah, that sucked
Old Mar 29, 2005 | 02:42 PM
thanks ill check it out and hopefully it wont be anything too serious
Big Little Bear
230
Nov 13, 2023 11:42 AM
kawazx636
Oct 6, 2021 03:03 PM
tylermx71
Sep 29, 2015 08:49 PM
dbollier123
Sep 29, 2015 05:23 PM
Cycles
Sep 29, 2015 06:37 AM
