Question about gasket and pipe(egr?)
Old Mar 26, 2005 | 03:20 PM
fadetoblack72's Avatar
Ok. There is a small pipe that runs form one side of the motor around the back and attatches to the intake manifold about half way down. I got the gasket kit(ITE) and it doesn't seem to have a gasket for this fitting. I guess the question is can I just use blue rtv? Should I used Red(High temp)? Or do I NEED to get that gasket? What is this pipe for? I am guessing EGR or something like that. Maybe a water pipe. It comes off of the passenger side and goes back to the manifold. I don't know where it actually comes from because I have the motor apart.
Thanks for the help,
Jason
Old Mar 26, 2005 | 03:30 PM
kyle_22r's Avatar
which engine?
some engines had air injection, a pipe goes from a smog pump to the exhaust manifold. the EGR pipe is a straight piece that goes from the EGR valve to the port on top the intake manifold.
Old Mar 26, 2005 | 04:01 PM
Nope. This metal pipe comes from the bottom of the intake manifold and goes around the back of the engine and to the drivers side then a piece of rubber hose connects to it. The pipe and hose are about 3/4" in diameter. The pipe runs along the back of the motor with the metal pipe that comes off of the exhaust manifold. The motor is a 22re. Seems to me this would be a water type pipe as it is attatched to a rubber hose. Why they didn't send a gasket who knows.
Thanks. Hopefully this explains it better.
Old Mar 27, 2005 | 04:25 AM
Anyone?
Old Mar 27, 2005 | 04:52 AM
Arnold's Avatar
That sounds like a coolant pipe and should have an o-ring between the pipe and intake manifold. Let me see if I can find a pic and see if we're talking about the same thing....
Old Mar 27, 2005 | 05:00 AM
Arnold's Avatar
Got the pic from the pirate board.
Does the pipe bolt on to the where the arrow is pointing?
Old Mar 27, 2005 | 05:09 AM
Exactly the one. so it should have an o ring? I'll try to find it in the gasket kit. I don't need any aditional sealer? I had 2 for those metal looking gaskets that are for high temps and I used them on both ends of the pipe of the same size that runs off of the exhaust manifold. Hope I have them right. I have 2 extra silver gaskets in the kit and no clue where they go. Will I have extra gaskets?
Thanks so much for the help,
Jason
Old Mar 27, 2005 | 06:16 AM
Arnold's Avatar
Yup, an o-ring sits in that recessed area of the manifold and no sealer is needed. Not sure about the silver gaskets though.
Old Mar 27, 2005 | 06:44 AM
kyle_22r's Avatar
i used a little gray RTV on the o-ring on my coolant pipe, then torqued the bolts down nic e and tight, as the o-ring was wider than the recess. holding up fine so far
Old Mar 27, 2005 | 12:45 PM
I uess have the o ring them as the one i have is bigger than the recess. I don't know why it wouldn't be the actual size of the recess. Well I guess I'll either get another ont or use that one and sone flexible gasket former.
tj884Rdlx
Aug 28, 2015 12:04 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
