Tire Size Question???
Old Mar 25, 2005 | 07:03 PM
YeloSub7's Avatar
Question Tire Size Question???
I am going to do the 1.5" ball joint spacer lift on my second gen 94' runner. I am running 31" tires right now, stock. So with a 1.5" lift, how big of tires can i fit? Can I fit 32"s? Anyone who has done this let me know, cause I am gonna need new tires soon. Thanks for helpin out...
Old Mar 25, 2005 | 07:06 PM
DudeBud's Avatar
well might be able to get 33s what are you doing for the rear?
Old Mar 25, 2005 | 07:10 PM
YeloSub7's Avatar
either downey 1.5" springs or cruiser coils... but can 33's fit without rubbing or haveing to trim? or would 32's be good?
Old Mar 25, 2005 | 07:14 PM
DudeBud's Avatar
to be safe go with 32s
Old Mar 25, 2005 | 07:15 PM
Marc P's Avatar
I have BJ spacers and Downey coils-putting 33x10.5x15 BFG AT's on tomorrow(have 31's now)--I will let you know how they fit.
Old Mar 25, 2005 | 07:16 PM
YeloSub7's Avatar
So I can definately fit 32"s not prob then?
thanks for the help...
Old Mar 25, 2005 | 07:24 PM
4Crawler's Avatar
Usually you can fit 32s w/ no lift an a little trimming, so w/ ball joint spacers and some rear lift, should fit no problem, unless you run a very wide or offset wheel.
For 33s, most folks add a 1" body lift with the spacers.
Old Mar 25, 2005 | 11:17 PM
4rnr's Avatar
Ive cranked in about .75 in. in my front and i run 33x12.50 no rubbing
Old Mar 26, 2005 | 07:57 AM
YeloSub7's Avatar
WHat would be the recomended back spacing with 32's?
Old Mar 26, 2005 | 07:59 AM
YeloSub7's Avatar
That would be great if you let me know how that turns out...
:beach: :beach: :beach:
Old Mar 26, 2005 | 08:03 AM
YeloSub7's Avatar
I was told that you can't put a body lift on a second gen with an automatic transmission, which is what I have. Is this true?
Old Mar 26, 2005 | 06:41 PM
yote4x4's Avatar
Not entirely true
Its sort of true. I have a Performance Accessories 3" body lift and the shop had to get a combination of two kits because of the auto transmission. It was alot of work but it can be done. I would have done it myself but I didn't feel like messing with two different kits. Maybe other people haven't had this problem, but then again it might have been because I have one of the last SR5 Limiteds to roll off the assembly line in 95. Let me know know it goes tho
Old Mar 26, 2005 | 08:33 PM
4Crawler's Avatar
Not a problem, been making A/T brackets and body lift kits for years:
http://www.4Crawler.com/4x4/ForSale/...html#ATbracket
Old Mar 27, 2005 | 09:15 AM
Spark-e3's Avatar
I've been running BFG M/T 32x11.50x15's first w/o any adjustment to stock sus. and just a little rubbing on rear of front fenderwells when in the sand(very bumpy). Mostly on the plastic. Yesterday, I raised front end 1.5" via torsion bars and went out..........no rubbing so far. The rear is next for me.
Good luck!!
bump
Old Mar 27, 2005 | 01:17 PM
YeloSub7's Avatar
Well thanks guys, that helps alot...
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Yotoder865
Jul 9, 2015 07:51 PM
