Tint Removal
Old Mar 23, 2005 | 12:25 AM
lanai's Avatar
Tint Removal
I want to re-tint my windows with a darker tint. What do you remove the existing tint?
Old Mar 23, 2005 | 01:42 AM
Tacoma Dude's Avatar
Here's a good link:
http://www.tintdude.com/remove.html
I'd suggest reading beyond the instructions as he's got some stories at the bottom that might interest you.
Old Mar 23, 2005 | 04:21 AM
Pat2002SE's Avatar
I used "Goo gone" and a ton of paper towels. The Goo gone will leave a little film on the glass which I cleaned up with Windex. It takes a bit of muscle and it comes off in little sticky balls. You can buy Goo gone at any paint or hardware store. Be sure to atleast have the door open because it starts to smell pretty powerful after a while.
Old Mar 23, 2005 | 05:31 AM
DUOGLIDESS's Avatar
windex and a razor blade soak the glue down good and use the razor blade to remove it and then clean with paper towels pretty easy job don't spare on soaking the glue with windex and you may have to spray it a couple of times before you get it all
Old Mar 23, 2005 | 05:55 AM
Bluto's Avatar
I used the garbage bag - Ammonia method. Worked great. Wear goggles and a cartridge respirator.
Old Mar 23, 2005 | 07:39 PM
99Tacoma4x4's Avatar
Peel tint off first ( if good quality tint it should come off in big sections ) Then use glass cleaner or I always put water in a spray bottle then add liquid soap, this way it won't suds up. Spray the glue, soak it good. Use a razor blade and it will come right off. Nice and slimy mess!!!! Before you retint your windows you need to really make sure there are no glue at all left on the windows. It will show up and look awful.
Old Mar 23, 2005 | 08:00 PM
slustan's Avatar
peel tint and used acetone, worked great for me, wear gloves and a respirator
Old Mar 24, 2005 | 06:02 AM
lanai's Avatar
Thanks for your help guys.
Old Mar 24, 2005 | 12:14 PM
2001Millrunner's Avatar
This is what the pros do
Old Mar 24, 2005 | 09:41 PM
89macrunner's Avatar
im thinking heat gun and razor blade..heat guns are a lot of fun..hahaha
mulewright
Sep 28, 2015 10:27 AM
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
FJtoyman
Sep 8, 2015 04:47 AM
gp66
Sep 7, 2015 08:29 AM
