got poked
Old Mar 22, 2005 | 12:33 PM
ajz399's Avatar
got poked
I was checking my trans fluid with my 1994 running and one of my spark plug wires gave me a nice shock, do i need new wires or a new distributer cap and am i losing power from this?
Old Mar 22, 2005 | 12:42 PM
epic37311's Avatar
Old Mar 22, 2005 | 12:51 PM
Flamedx4's Avatar
To test the plugs wires - pull one off a spark plug and hold it to the tip of your tongue.... KIDDING!! Dont do it!
Tonight when it's dark, run your engine and look under the hood. If you see arcing, then you need new wires badly! If you see not arcing, move them around a bit like you did today and if you still see no sparkies, you can forget em. Even though volts are high, amperage is low, or it would be very dangerous to work around the ignition wires with the engine running. Getting shocked by a spark plug wire will make you jump but it is not particularly harmful.
Also, you might want to check your plugs (condition, gap etc) and make sure the engine to frame ground is clean and secure.
Old Mar 22, 2005 | 12:55 PM
Mickdady's Avatar
as with the above suggestion, spray soapy water on the wires. if they are cracked or grounding, you will get a miss and should be able to see a visible arc.
Old Mar 22, 2005 | 01:33 PM
jimbo74's Avatar
unless you have a pacemaker ... otherwise you'll be fine
Old Mar 23, 2005 | 02:14 PM
Flamedx4's Avatar
My magnetic personality sometimes erases my harddrive...
Old Mar 24, 2005 | 05:34 PM
tman6508's Avatar
u know it only takes 1, yea o-n-e amp to stop your heart.
Old Mar 24, 2005 | 07:24 PM
Yamaha+Toyota=Fun's Avatar
I thought it was like half an amp.
Either way, I dont think there is anyway a spark plug wire could kill you. Then again, I probally shouldnt say that.....
Old Mar 24, 2005 | 07:28 PM
jimbo74's Avatar
when i first read this thread, i was like WHOA! you cant put stuff liek that on yt.... i have a dirty mind, so imagine what i was thinking....
Old Mar 24, 2005 | 07:40 PM
96LtdYota's Avatar
one amp can kill, but at how many volts i might ask....
Old Mar 24, 2005 | 08:57 PM
Yoda's Avatar
If ya got bit, change the wires! You already have the "proof" there is voltage leaking.
Working on cars I have been bit several times. Early HEI ignitions system HAVE killed people. I have been zapped with 440 volts, 400hz on aircraft. The hardest hit I ever got was 120 volts DC. Couldn't let go, blacked out, fell backwards off the bench I was on (that disconnected me and slapped me back to life).
Old Mar 24, 2005 | 09:17 PM
DudeBud's Avatar
saying got poked in the title made me laugh i was thinking about something else anyways get some new wires
Old Mar 24, 2005 | 10:31 PM
green91runner's Avatar
volts don't really matter, some stun batons run at 300,000 Volts... but anything over 70 milliamps can kill you, keyword CAN, means it may not.. but, why tempt fate?
raptor510
Feb 17, 2017 07:11 AM
theking11863
Mar 19, 2016 09:36 PM
Peach
Jul 3, 2015 09:30 AM
woody77
Jan 15, 2006 02:55 PM
