starter soleinoid contact part #s
Old Mar 23, 2005 | 10:18 PM
Tacotex's Avatar
Just finished replaceing the battery side contact in the '98 3.4L 4runner-motor side was fine. Only removed the wheel (not necessary) and rear skidplate for access. The battery side contact lists for $6.32, and the motor side $11.89 at the dealer.
Battery side contact Toyota P# 28226-54340
Motor side contact Toyota P#28226-72080
Thanks to all for the write ups. Wish I'd known about this fix before I bought a reman. starter for my '93 truck a couple of years ago...
Old Mar 23, 2005 | 11:36 PM
jimbo74's Avatar
if you check out roger brown of www.4crawler.com he has a writeup on the replacement and sells the parts too
Old Mar 24, 2005 | 06:32 AM
valkyrie610's Avatar
A TTORA guy (Boo) has a great write-up here also:
Starter Rebuild
He just finished it, so if you see something you think he should change/add, he is receptive to feedback.
Old Mar 24, 2005 | 01:26 PM
4Crawler's Avatar
I'll add that new repair link to my starter repair page:
http://www.4Crawler.com/4x4/CheapTricks/Starter.shtml
Old Mar 24, 2005 | 06:28 PM
motherhucker's Avatar
Thanks!
Thanks! Ive been lookin for the part #'s for the 3.4 contatcts. The wifes 99L just started clicking.
Only 53k miles on it, seems a little early to me?
Old Mar 24, 2005 | 07:58 PM
4Crawler's Avatar
Best bet is to follow some of the diagnostic tests on my web page (link below). Specifically see if you can test the voltage at the solenoid control wire and see if there is a difference between when it works and doesn't. If the voltage is not within 1/2 volt of the battery voltage, then you may have a problem upstream of the starter/solenoid. If the voltage is solid, then it is likely inside the solenoid, a quick peek at the contacts inside the solenoid would #1 confirm, they are worn and #2 which shape contacts you need to replace:
http://www.4crawler.com/4x4/CheapTri...ostic tests...
Old Mar 25, 2005 | 05:02 AM
Tacotex's Avatar
Nice write up 4crawler
Yours was the best I found, and was all I needed to solve this little problem. Kind of impressed the wife in the process
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
thefishguy77
Jul 30, 2015 10:59 AM
ZONAYODA
Jul 13, 2015 07:17 PM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
