installing stock carb to replace shot weber
Old Mar 25, 2005 | 02:16 PM
PO2SIMS's Avatar
There are 2 lines for fuel, 2 different sizes. Can someone tell me which line connects to fuel pressure, and what the other line is and what it connects to? Also, are there any vaccum lines I can plug? Anyone that could post some pics also, thanx.
Old Mar 25, 2005 | 05:31 PM
kyle_22r's Avatar
the little barbed line on the driver's side is the fuel inlet, the big one on the passenger side is a vent or a fuel return(mine's plugged).
you can ditch all emissions lines by using the diagram i posted in this thread. i'm running this setup on my truck and it works flawlessly.
also if you don't have the stock round 4 pin connector for the carb wires, you can run the red choke wire and black wire from the solenoid to a switched power source(the red wire going to the ignition box is good) and the black and white wire from the solenoid to a ground source. the black wire from the little box on top the carb in the front can be left alone
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
