I need some help
Old Mar 22, 2005 | 04:48 PM
tysenstoy's Avatar
Question I need some help
When I turn on my left turn signal it blinks at normal speed but, when I put my foot on the brake it speeds up like I have a bulb blown' but I don't. What else could it be???
Old Mar 22, 2005 | 07:09 PM
green91runner's Avatar
i would guess it to be a short of some kind when the pedal is depressed.. wouldn't know where to begin troubleshooting it
Old Mar 22, 2005 | 07:31 PM
YotaJunky's Avatar
Start from the light and work backwards. I had the same problem and it turned out to be a loose connection.
Old Mar 22, 2005 | 09:51 PM
photoleif's Avatar
quick flashing is most commonly coded to indicate that a lamp is burnt out *somewhere*. check all the bulbs and i bet you'll find the defective one. what troy said above is great advice. assume it's a bulb, and if not that after testing them, then you'll need to trace connections and beyond, for an open circuit that *acts* like a dead bulb.
Old Mar 29, 2005 | 03:48 PM
tysenstoy's Avatar
thanks y'all. I'll try it all.
