trembling engine
Old Mar 22, 2005 | 06:37 PM
Eneas28's Avatar
trembling engine
I have a 4 runner 95 V6 Auto.It has not stoped trembling since a bought it.I changed the fuel filter,cleaned the TB,changed the plugs,PCV and wires.But the problem does not go away.Is also loosing power.I'm even using the best gasoline.Don't know what the problem is.A friend of mine told me that it might be one cylinder is not working well.Can anybody help me if you understand me now.Do you need more info?
Old Mar 22, 2005 | 06:57 PM
Ontario's Avatar
Sorry, I can't help but I can sympathize. Sounds like I have the same thing. Does it happen all the time? Is it when you are idling or when you are accerating too?
Old Mar 22, 2005 | 07:41 PM
green91runner's Avatar
have you done a compression test? the 3VZE is notorious for burning #6 (thx to toyota's wonderful crossover design)
Old Mar 22, 2005 | 10:33 PM
humanoid's Avatar
Yeah, try compression testing it. Also, you might have a vacuum hose loose or something. I was cleaning out my throttle body one time and a hose came loose that I didn't see. Started the rig up and sounded like it was missing. After a long search, I discovered that a vacuum hose had come loose right under the throttle body. Re-attatched it and it ran like new.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
