Temp guage issues
Old Mar 22, 2005 | 07:05 PM
evilcow's Avatar
Temp guage issues
When I start my truck the temp guage instantly redlines and stays there. Even when its cold. Whats up with that?
Old Mar 22, 2005 | 07:12 PM
FilthyRich's Avatar
electirc gauge taking a dump??my temp gauge on the 99 always reads cold.
Old Mar 22, 2005 | 07:19 PM
evilcow's Avatar
I guess. Could it be the gauge or something else?
Old Mar 23, 2005 | 09:20 AM
KING's Avatar
Does it return to normal after a few seconds of engine running?
Mine shoots to nearly red after its been driven for a lenghty period of time and restarted. However, after the engine has been running for seconds, it returns to normal.
Old Mar 23, 2005 | 10:19 AM
4Crawler's Avatar
Sender, gauge or wiring is shot. Factory Service manual should list the resistance tests for the sender and gauge, if they check out then it is the wiring. A quick test is to disconnect the sender and see what the gauge reads, then short the sender wire to ground and see what the gauge reads. I think normal operation is that disconnected=cold, shorted=hot.
Old Mar 23, 2005 | 10:50 AM
jimbo74's Avatar
its a 22re, hmmmm.... temp overshoot problem needing the upgraded 2 stage thermostat? check out 4crawlers site for info on it... it says for 87, but in reality, its all the 22r and re engines... my truck did the same thing, put in the 2 stage thermostat, been all better since
Old Mar 23, 2005 | 06:43 PM
SoCal4Running's Avatar
My temp guage is completly disconnected and it still moves the needle every once and a while. I do not trust the 1st gen temp guages, get a mechanical.
Old Mar 23, 2005 | 06:54 PM
Marc P's Avatar
I went mechanical. My stock one would be normal, the when truck was put under any load it would peg to the cold side--that sucked.
Old Mar 23, 2005 | 07:20 PM
Me too
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Nickyodaman
Jul 27, 2015 12:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
