check engine light
Old Mar 21, 2005 | 04:30 PM
ajz399's Avatar
check engine light
1994 4runner ce light came on,I did the diagnostic check and my cruise control and antilock brake lights flash non stop,my ce light stays lit and doesnt blink,WTF?
Old Mar 21, 2005 | 04:57 PM
Marc's Avatar
Are you sure you're shorting TE1 and E1?
Old Mar 21, 2005 | 05:03 PM
ajz399's Avatar
i did this from a earlier thread-
If you look by the fuse box in your engine bay on the passenger side, there is a small grey box next to it labeled "DIAGNOSTIC". Open that up and you will see a bunch of terminals. There are two terminals you need to jump to pull codes, they are "E1" and "TC". There should be a diagram with labels on the cap IIRC. Jump these with a wire or something that is conductive and watch the blinks when you have the key turned to ON (you have 4 seconds to get from the diagnostic box to the cab where you can see the CEL
Old Mar 22, 2005 | 07:12 AM
Marc's Avatar
I believe E1 to TC is to test the ABS.
Try TE1 to E1
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
