is my timing[belt] right on?
Old Jan 25, 2005 | 10:50 AM
rivercat's Avatar
put the timing belt on as the book says, cranked the engine over by hand twice around. each time the belt goes around it ends up one knotch back, so 2 revolutions 2 teeth off... the timing marks on the oil pump and tbelt sprockets line up perfect. this is my first time setting the timing on a 3vze so i was a little worried about the belt ending up one tooth back per revolution... so is the timing on or am i missing something?
Old Jan 25, 2005 | 12:21 PM
rivercat's Avatar
i know some can help with this... the book just doesn't have the details i need, if i were to go with mu instinct and the book i would think that my timing is right on...
Old Jan 25, 2005 | 12:34 PM
PirateFins's Avatar
here is the FSM procedure if it helps. timing info
Old Jan 25, 2005 | 12:37 PM
Yoda's Avatar
You going to be home Tues night? I'll stop by and check for ya.
Old Jan 25, 2005 | 12:48 PM
rivercat's Avatar
ya i'll be here all day... i think i have it right as after two rev's the marks on the pulley's and tbelt cover always line up, just the marks on the tbelt don't which i suppose doesn't really matter... this just isn't something i want to mess up, known to many people that have gotten into piston valve clearance issues this way, don't want to give myself that chance
Old Jan 25, 2005 | 01:42 PM
Bumpin' Yota's Avatar
the marks on the belt arent that big of a deal....
Just make sure that the crank gear lines up with it's mark and that the 2 cam gears always line up with their spots.
Dont forget on the belt the 'R cam' is for the engine's right side cam, not your right as you face the engine....
Posting pics of the gears you need to line up...
Heres a pic of the crank gear, note the notch on the top of the gear and the mark on the oil pump that it must line up with.
Old Jan 26, 2005 | 08:20 AM
rivercat's Avatar
thanks i think i got it...
Old Jan 26, 2005 | 08:22 AM
Jared Ajlouny's Avatar
the belt is going to be off after revolutions, the marks are not evenly spaced
Old Jan 26, 2005 | 10:39 AM
Yoda's Avatar
I stopped by last night but got no answer at the door. Looked at the truck, but the marks weren't in "set up" position (looked OK, just rotated past the index)
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
