I got a problem
Old Jan 22, 2005 | 01:55 PM
cccp's Avatar
Question I got a problem
Hey guys this is Greg i got a 1990 toyota 4 runner and just now i found out i am leaking engine oil. What should i do to stop it. It is not really leaking that much except for little drips.
Old Jan 22, 2005 | 02:01 PM
forty4's Avatar
figure out where the leak is coming from and replace the gasket it is coming out of, or you might be able to get away with just tightening a bolt. at any rate, you need to know more precisely where the oil is coming from.
Old Jan 22, 2005 | 02:10 PM
cccp's Avatar
i think the oil is leaking because of the gaskets. But do u think I should put some engine oil stop leak in my oil.
Old Jan 22, 2005 | 02:12 PM
kyle_22r's Avatar
don't put that crap in your oil. which gasket is it leaking from?
Old Jan 22, 2005 | 03:34 PM
Bigblock's Avatar
i bet it's a seal,not a gasket.make sure your valve cover isn't carboned up.
Old Jan 22, 2005 | 03:38 PM
Paul H.'s Avatar
Where is it coming from?
Old Jan 22, 2005 | 07:28 PM
cccp's Avatar
i belive it is comming from a valve cover.
Old Jan 22, 2005 | 07:32 PM
98LimitedCustomized's Avatar
My grandpa had a BAD leak at the head gasket on a Ford (POS's!) 5.0 V8. He used a product called RESTORE if I remember correctly at an oil change and the leak completely stopped. He's not one to fall for a BS product, but he swears by it. Might be worth a try.
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
