Diff drop...easiest mod ever!
Old Jan 24, 2005 | 09:16 AM
HaveBlue's Avatar
I spent most of Sunday doing odd jobs on the 4Runner and Camry. On the 4Runner, I replaced the belts, installed a 170° NAPA thermostat, flushed the radiator, drained a few quarts of fluid from the transmission (don't like the looks of the fluid), put in some Sea Foam Trans Tune and a quart of Trick Shift, and then decided to install my diff drop kit since the skid plates were off. It took more time to drain 2.5 qts of fluid from the tranny than it did to install the diff drop. And an impact wrench made removing the old bolts a cinch.
Old Jan 24, 2005 | 10:09 AM
GTE4runner's Avatar
Where did you get the kit and how far did it drop it? Pics? Sounds cool, that would make the supra swap with IFS easier for sure...
Old Jan 24, 2005 | 05:02 PM
Bigblock's Avatar
start yakkin feller.
Old Jan 25, 2005 | 11:28 AM
4Crawler's Avatar
I think Alan used my diff drop kit. It provides a 1" drop:
http://www.4Crawler.com/4x4/ForSale/DiffDrop.shtml
Old Jan 27, 2005 | 07:42 AM
HaveBlue's Avatar
I did indeed use a 4Crawler diff drop.
Old Jan 27, 2005 | 10:27 AM
boogyman's Avatar
Talking
I just used some 2" zinc plated washers from yard birds with longer bolts. I stacked about 8 washers to give me about an inch. Whole setup cost me under $5 and it's been on for well over a year with no problems at all; rust, loosening, or anything.
-Russell
Old Apr 24, 2005 | 12:06 PM
Ric's Avatar
Ric
Banned - User requested
i know this is an old thread, ( using the search ) does any one know of a place in the Denver metro that sells the drop kits ? if so please let me know,
Ric
Old Apr 24, 2005 | 01:05 PM
photomike72's Avatar
is that for 3rd Gen only? Does anybody do a 2nd Gen kit?
Thanks,
Mike
Old Apr 24, 2005 | 01:09 PM
leebee's Avatar
try this thread:
https://www.yotatech.com/forums/showthread.php?t=57463d
this should help you out.
lee
4Crawler's Avatar
As soon as someone can provide me with the specs on the stock diff mount bolts for a 2nd gen (length and dia.) as well as the bolt specs on the sway bar mount brackets (length, dia. and spacing) I can come up with a 2nd gen diff drop kit similar to what I make for the 3rd gens:
http://www.4crawler.com/4x4/ForSale/DiffDrop.shtml
Old Apr 24, 2005 | 01:35 PM
Sweet. ANybody have this info laying around for 4Crawler?
Mike
Old Apr 24, 2005 | 02:17 PM
r0cky's Avatar
Mike, I'm in Dallas and have an extra diff drop kit around from 4Crawler.
Old Apr 24, 2005 | 02:27 PM
rimpainter.com's Avatar
Alan-
What do you think of that 170 degree thermostat? I am considering one too before I get my SC'r put in. Thanks.
Old Apr 24, 2005 | 02:49 PM
kevin444's Avatar
You should get a 160deg tstat?
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Badlander
Oct 10, 2015 08:05 PM
oldblue
Sep 28, 2015 04:07 PM
Odin
Sep 26, 2015 06:56 PM
