Throttle Position Sensor
Old Jan 24, 2005 | 09:05 AM
Bassinfool's Avatar
Question Throttle Position Sensor
I'm getting a code 41 (Throttle Position Sensor) & my engine (3vz) is idling a bit high. Thinking I may need a new Throttle Body, but wanted to see if anyone had this before & maybe it's a cheaper fix???
Old Jan 24, 2005 | 09:52 AM
rimpainter.com's Avatar
Test it to be sure.
Old Jan 24, 2005 | 09:56 AM
Bassinfool's Avatar
Originally Posted by <96 Runner>
Test it to be sure.
How do I test it?
Old Jan 24, 2005 | 10:03 AM
FSM or similar and a multimeter. Not that hard really.
Old Jan 24, 2005 | 10:06 AM
MTL_4runner's Avatar
Originally Posted by Bassinfool
How do I test it?
The resistance should vary linearly as the throttle is opened.
FSM will tell you if the resistance is within spec or not.
Old Jan 24, 2005 | 10:32 AM
PirateFins's Avatar
here is the FSM procedure for testing it.
http://personal.utulsa.edu/~nathan-b...93throttle.pdf
Old Jan 24, 2005 | 10:36 AM
Pretacopower's Avatar
you shouldn't need a new throttle body just because the sensor goes bad.
Mine went bad a couple months ago and Toyota replaced the sensor. Then all was good.
Old Jan 24, 2005 | 03:19 PM
Bassinfool's Avatar
Do you know how much the sensor by itself was?
Old Jan 24, 2005 | 06:52 PM
Honestly, no. It was covered under my extended warranty so I only had to pay the "diagnostic" fee.
Give your local toyota dealer a call and they should be able to tell you a price.
Old Jan 24, 2005 | 07:58 PM
Babypig's Avatar
I've got two that are less than six month old if you need one. They do dead spot after awhile so you may just need a new one or it may just need adjusting. Deffintely try the adjusting first. Get a multimeter and some testing clips for the meter. It makes it easier to test.
Old Jan 24, 2005 | 08:36 PM
Bassinfool's Avatar
Cool, thanks guys. I'll give it a test tomorrow & see what's up.
Old Jan 25, 2005 | 07:47 AM
Bassinfool's Avatar
OK, hopefully this isn't as stupid of a question as I think it's going to be... on the page you gave me, it says to "Insert SST between the throttle stop screww & stop lever..." What the hell is an SST? (if I don't know what that is, is this something I should have the stealer do?)
Old Jan 25, 2005 | 07:51 AM
WATRD's Avatar
SST == "Special Service Tool"
Sometimes an SST is a tool that is required to get a job done. More often it's a tool that makes the job easier, but you can figure out other ways to do the job using ordinary tools that you probably already have. There's a zillion SST's listed in the service manuals. You will have to be creative and figure out if this is a job you can do without it or if it's one of the rare cases when the tool is a must have.
Old Mar 19, 2005 | 06:09 PM
trd6209's Avatar
quick question that probably has an obvious answer. the FSM gives directions to adjusting the TPS while it's off the motor, but it says "Apply a vacuum to the throttle opener" What's the best way to do this while it's on my bench?
Old Mar 20, 2005 | 04:11 AM
Something like this:
Old Mar 20, 2005 | 08:22 AM
4Crawler's Avatar
Here is my TPS adjustment/testing page:
http://www.4crawler.com/4x4/CheapTri...#TPSAdjustment
crammit442
7
Nov 29, 2017 12:30 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
