integration relay
Old Jan 23, 2005 | 08:33 AM
northern toyota's Avatar
Question integration relay
What does this exactly do, can I bypass it , how much for a new one, and do they make aftermarket one. The problem is that I don't have running lights, dash, speedo, fuel gauge, temperature, interior lights, I keep blowing the gauge fuse. I have this plugged in it blows the fuse, have it unplugged and it does not blow fuse, also where can I get schematics online for my truck, it is a 98 tacoma.
Old Jan 23, 2005 | 08:51 AM
Ironmike4x4's Avatar
Well check the wires, you know you have a short to ground if the fuses are blowing, try to check and see if they are getting to the load before it grounds. Also check for loose or frayed wirings. It costs money but if you join alldatapro.com it gives you very helpful stuff for vehicle repairs.
Old Jan 23, 2005 | 08:54 AM
Thanks I checked all the wiring and repaired all the nessasary wiring and the fuse still blows, is it possible that this unit is blown up itself. It is my last option.
Old Jan 23, 2005 | 08:57 AM
Check the unit itself.... I know it may sound odd, but once at my dealership we had a truck come in and a nail was in the dash panel. Everytime the Speedometer read anywhere above 20mph it went dead to zero. Come to find out, the poteniometer was shorting itself out once it read the 20 mark. If not then get some type of manual to test the unit itself.
I8URSVT
Jan 15, 2016 07:25 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
