rear output flange leak
Old Jan 22, 2005 | 05:22 AM
brendonv's Avatar
ive got an 87 pickup, i recently installed the all pro transfer case mounted e brake, when i took the rear output flange out, there was some RTV on the nut, when i installed it back on, i didnt use any, now there is a small leak coming from it...is it OK to use RTV?
thanks
Old Jan 23, 2005 | 05:29 PM
brendonv's Avatar
T O P
Old Jan 23, 2005 | 06:36 PM
4Crawler's Avatar
The RTV is used to seal the splines from oil. There is also an oil seal inside the t-case that rides on the outside of the flange. See if you can find where the leak is coming from (inside around the nut or outside) and fix the source.
Ladythump
22
Nov 9, 2015 08:53 AM
redneck17
Oct 29, 2015 09:09 PM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
