Shackle lift
Old Jan 23, 2005 | 05:34 PM
blainelukens's Avatar
Shackle lift
Ok so I got a 2" shackle lift for my 89 pickup to level out the front and back fenders. I guessing I would need shocks that are 3-4" longer than stock, and some new polly bushings, right? Someone told me I would have to check to u-joints and the drive shaft because they would be out of alignment because of the lift. Is this true, and if so what would I do? I have done some research about this and I figured all I need is new shocks. Any feedback would help.
Thanks
Old Jan 23, 2005 | 06:11 PM
4Crawler's Avatar
Are these a 2" lift shackle or 2" longer than stock?
http://www.4Crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
Shocks should be longer by about the amount of lift, but best to measure and see what you need:
http://www.off-road.com/toyota/travel.html
And also, measure your driveshaft angles:
http://www.4crawler.com/4x4/CheapTri...l#Measurements
And corrrect if needed:
http://www.4Crawler.com/4x4/ForSale/Shims.shtml
Old Jan 24, 2005 | 04:08 AM
they are 2" longer than stock
Old Jan 24, 2005 | 06:23 AM
4Crawler's Avatar
Then, those are only good for about 1" of lift. You may be fine with your existing shocks, but easy to check and see. Just measure the shock extension at full dropp and compare that with the extended length fo the shocks.
suppra87
Jul 15, 2021 05:15 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
punks_is_4x4
May 31, 2016 06:03 AM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
