Rear window woes.... reloaded...
Old Jun 25, 2005 | 05:18 AM
david in germany's Avatar
Ok I probably have a typicle problem with my rear window.. I have fixed almost every wire in the rear harness at least once and it would work for a while then the next wire would break.. this time I think it may be the relay... I got the window down and now I can't get it back up... I heard the relay clicking untill today and now nothing... Is there a way to test the relay? I have 12v at the relay. where and what else should I check?
Thanks all!
David
Old Jun 25, 2005 | 05:38 AM
leebee's Avatar
go to www.4crawler.com and check his quick tips, he has a great write-up on the rear window and how to trouble shoot.
lee
Old Jun 27, 2005 | 10:30 AM
Thanks Lee but I have been a frequent visitor of roger's site for a while now. I have also replaced all the relays in the control box and I can actualy jump the connctions at the switch and at the relay box to get the window up and down but still the keyswitch and the front switch do nothing. I am lost....
I think that the control box is good and I can also get the wiper to work without a problem with the switch. could the key switch being bad cause the front switch not to work? I will try anything to get this thing working again....
Thanks all.
David
Jun 1, 2021 01:51 PM
RustBucket
Jul 24, 2015 04:46 AM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
