what is this mini rad in front of my rad
Old Jun 21, 2005 | 02:49 PM
Godzilla's Avatar
May be a stupid question but i just moved up from a 5spd 92 to an auto 99 and i was looking at my rad just now and there is a mini rad in front of the normal radiator. what is this? tranny or oil cooler? or something else?
Old Jun 21, 2005 | 02:50 PM
CoedNaked's Avatar
Tranny Cooler
Old Jun 21, 2005 | 03:06 PM
Godzilla's Avatar
thanks. i thought so , but im still trying to get acquainted with a 3rd gen auto.
Old Jun 21, 2005 | 03:21 PM
CynicX's Avatar
Directly in front of the rad is your A/C condenser. Its about the size of the radiator but its really thin.
If you have a smaller radiator infront of that like 1'x1'x1" then yes thats a transmission cooler. I believe that would be aftermarket the stock tranny cooler is built into the radiator. TRD makes a kit or you can get tranny cooler from Hayden. Here is what a tranny cooler looks like.
I used that pic so you can compare the size too that quart of fluid next too it.
You can trace the lines too. If it has steal lines running all over the place then its an A/C condenser. If it has rubber transmission fluid lines its a tranny cooler.
Old Jun 21, 2005 | 06:19 PM
94x4's Avatar
Guest
There's no such thing as a "stupid question"...only people too stupid to ask a question.
Old Jun 21, 2005 | 06:43 PM
rearviewmirror's Avatar
So where do I look to see if I have a stock transmission cooler?
Old Jun 21, 2005 | 07:32 PM
Cebby's Avatar
Generally, your radiator has tranny fluid running through part of it for cooling. Adding an auxilary tranny cooler is a good preventative measure.
WellsR
12
Jul 31, 2015 03:27 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
highonpottery
7
Jul 18, 2015 02:48 PM
dinks07
Jul 15, 2015 05:34 PM
Edionne13
Jul 9, 2015 01:59 PM
