Engine cooling question
Old Jun 30, 2005 | 11:40 AM
fo_runner's Avatar
I have one question concerning that coolant additive called Water Wetter from Redline. Does it really work like it says, or is it another gimmick?
My 3.0 seems to get really hott after a few minutes of driving. I hate getting burned when I work on the car after being driven
Old Jun 30, 2005 | 11:46 AM
4Crawler's Avatar
I use it in my 22RE. In a thermostat controlled cooling system, it will not reduce your coolant temps (the t-stat is what does that), but I find it helps control reduce the coolant surface tension which is supposed to help cut down on hot spots in the engine. You can really feel the difference rubbing your fingers together in the coolant once you add the stuff. I use it as more of an insurance policy in case something happens to the cooling system out on the road or trail. If you have problems in the cooling system, Water Wetter or similar products will likely not make it much better, fix the underlying problem first.
Old Jun 30, 2005 | 11:51 AM
Flamedx4's Avatar
Have your radiator core checked and cleaned, and put in a new thermostat. Check the hoses too. Shouldn't be running hot.
Old Jun 30, 2005 | 02:03 PM
AzStorm's Avatar
Engine Ice works better IMHO.
http://www.engineice.cc/
Old Jun 30, 2005 | 03:51 PM
callmej75's Avatar
What about this?
Question: Will installing a lower temperature thermostat help my engine run cooler and prevent it from overheating?
Answer: Yes, but it may cause more problems than it cures if you have a late model vehicle. Before emission controls and computerized engine controls came along, it was a common practice to install a cooler (160 to 180 degree F.) thermostat for summer driving. The lower thermostat lowered the engine's operating temperature, which in turn reduced the load on the cooling system and reduced the danger of overheating during hot weather driving or when towing a trailer.
It was also common practice to again replace the thermostat come fall and install one with a higher (190 to 195 degrees F.) temperature rating. This would raise the engine's operating temperature so the heater would put out more warm air on a cold winter morning.
This practice is no longer recommended because today's computerized engine control systems require a constant year-round operating temperature of about 195 degrees F.. The engine's emission controls as well as it's fuel and spark control systems are all calibrated to work within a given temperature range. If someone replaced the thermostat with the wrong one for the application (either colder or hotter), it can cause driveability, fuel economy, performance and emissions problems. So if the thermostat is replaced for any reason, it must be replaced with one that has the same (or correct) temperature rating for your vehicle.
HOW TEMPERATURE AFFECTS ENGINE OPERATION
Coolant temperature is used for a variety of engine and emission control functions. The coolant sensor on late model engines tells the computer when the engine has reached normal operating temperature. This, in turn, affects fuel enrichment, spark timing, operation of the EGR valve, purging of the charcoal canister, etc. Even on many non-computer engines, thermal vacuum switches (TVS) that react to a specific coolant temperature are used to open and close various vacuum circuits that regulate fuel enrichment, timing and emissions.
If a colder thermostat is installed, the coolant may never get hot enough to trigger the appropriate control functions in the computer or TVS vacuum circuits. As a result the engine will run as if it were continually cold, which increases both fuel consumption and emissions. Too low an operating temperature also increases cylinder wear.
CAUTION: Under no circumstances should an engine be driven without a thermostat! This can produce thermal stress that may crack a head or block!
What about a hotter thermostat? A hotter than normal thermostat in a late model computer controlled engine may activate some control functions too quickly or out of sequence with other control devices (timer delays, etc.) --which could also have an adverse effect on driveability, fuel economy, performance and emissions.
Sorry for the long post....but it seemed to fall into the same category of trying to make an engine run cooler.
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
