Help- grinding Noise?
Old Jun 27, 2005 | 05:11 PM
Brad's Avatar
Ok, just recently I started hearing a noise (sort of a light grinding sound) when I was slowing down at around 1500-2000 rpms. It only does it when I push the clutch in and it only does it occasionally. Everything shifts very smooth and the clutch doesn't grind at all or slip when I put it in gear or shift gears. Any thoughts????
Old Jun 27, 2005 | 07:02 PM
BajaRunner's Avatar
what area is the noise coming from? Are you braking?
Could be the u-joints. I had a weird whirrling chirping coming when I slowed down after long trips and it was the u-joints needing some grease!
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
