leaking rear end
Old Mar 15, 2005 | 03:29 PM
toy4weez's Avatar
Unhappy leaking rear end
Well seems that my 2000 4Runner rear end is leaking where the drive shaft goes in. Anyone know if this is just a simple seal here or am I opening a can of worms? Any suggestions on a shop manual for this truck also?
Old Mar 16, 2005 | 06:47 AM
george's Avatar
Its just a simple seal replacement. I have a 97 4runner and had to replace it twice. once at 78,000 miles and 90,000 miles on the driver side.
George
Old Mar 16, 2005 | 06:53 AM
ugadawg95's Avatar
George
Are you sure you are not referring to the axle seal? He said his is leaking from the driveshaft seal in the rear end.
Old Mar 16, 2005 | 06:58 AM
lee's Avatar
lee
sorry, i had to
Old Mar 16, 2005 | 07:04 AM
ugadawg95's Avatar
Did I miss something?
Old Mar 16, 2005 | 07:36 AM
RIS's Avatar
RIS
After you remove the rear section of the drive shaft all you should have to do is remove the nut that holds the yoke/flang on. It should be locked by way of punched into a "key way" slot. Use a small punch/chisel to unlock the nut then remove it. The yoke/flang should slide off with a few taps of a hammer. Now you should be looking at the seal. Pop it out with a large screwdriver and reinstall. Don't forget to relock that nut.
Old Mar 16, 2005 | 07:39 AM
lee's Avatar
lee
"leaking rear end"
Old Mar 16, 2005 | 07:45 AM
ugadawg95's Avatar
ohhh then it would be more like this...
Old Mar 16, 2005 | 07:54 AM
User 051420's Avatar
Sounds like a Pinion seal to me. IIRC, it's not an easy seal to replace.
Old Mar 16, 2005 | 08:14 AM
86toyota's Avatar
The problem with replacing the seal is the pinion nut. That nut has to be torqued back to the same specs as before. Overtightening will change the crush sleeve and preload on the pinion gear.
Read this
Old Mar 16, 2005 | 08:17 AM
rimpainter.com's Avatar
I take it you are out of the 5year/60K powertrain warranty, correct?
Old Mar 16, 2005 | 10:03 AM
Robinhood150's Avatar
I'd suggest you take it to a rear end shop and have then do it right. Shouldn't cost too much, mine was $40.
Old Mar 16, 2005 | 10:45 AM
RIS's Avatar
RIS
[QUOTE=86toyota]The problem with replacing the seal is the pinion nut. That nut has to be torqued back to the same specs as before. Overtightening will change the crush sleeve and preload on the pinion gear.
I'm butting gears in my 91 and the stock "crush sleeve" is a hard Sleeve. Much heavier than the crush sleeve in the master install kit.
Colington
Mar 8, 2020 09:51 AM
Daneums
Aug 20, 2015 05:36 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
toyoda8488
Jul 5, 2015 10:18 PM
