Cleaning a spray gun after use of bedliner
Old Mar 14, 2005 | 06:20 PM
Chapman88SR5's Avatar
hey guys hopefully this weekend ill bedline my bumpers. but i was wondering how i/if i can clean the spray gun after the use of the bed liner?
Old Mar 14, 2005 | 06:24 PM
waskillywabbit's Avatar
Only thing that I found that would take that crap off the gun...and be ready to do it often if you stop and let it harden in the spray gun...
Lacquer thinner and some thin pieces of wire to gouge down into it. I had to take my gun apart at least 5 times to clean it during the course of sparying a bumper using Duplicolor bedliner.
Good luck.
Old Mar 14, 2005 | 06:32 PM
thanks never thought of that... the duplicolor stuff is what im going to be using also. can i just put the thinner in the gun and spray it out to clean the nozzle
Old Mar 15, 2005 | 05:45 PM
anyone?
Old Mar 15, 2005 | 05:47 PM
anyone?
You'll have much better luck taking it apart and cleaning it out...believe me from recent experience, it will be gunked up.
Old Mar 15, 2005 | 05:52 PM
what kinda gun did u use? did u just buy the cheap one from walmart?
Old Mar 15, 2005 | 05:53 PM
I used the Duplicolor one and tried a Harbor Freight one, both clogged up after a while so paint as much as possible before you stop even for a minute cause once you stop, it clogs...
Lacquer thinner...
Old Mar 15, 2005 | 06:36 PM
slustan's Avatar
i dont know if its the same for the duplicolor but the herculiner can be thinned with xylol alcohol b/c that is what the base of it is. as far as cleaning it, acetone works pretty good as long as it hasnt hardened.
Old Nov 7, 2017 | 10:23 PM
ericalar001's Avatar
First of all, you need to remove its cape and nozzle. Then you need thinner for eliminating bed liner from the spray gun. It is the easiest way to clean your spray gun. If you want to buy a new spray gun for bed liner, click here.
chukarhunt
Dec 8, 2019 11:39 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
RobotMoose
Sep 2, 2015 05:53 AM
viesail
Aug 17, 2015 08:39 PM
