Should I, or shouldn't I???
Old Mar 14, 2005 | 07:02 AM
HOJU's Avatar
I've been trying to figure out where to put my Spare tire.... I can't fit it underneath, or inside, so my options are on top of the rack, or build a swing out tire carrier off the bumper are my two choices. I wouldn't mind it up top, but my MPG is bad enough already. If i built a tire carrier, what do you think it'll cost? what hinge should i use? will i need to remove the bumper to do it?(most likely yes, but you never know) and would it be worth it?
what do you think?
thanks
Old Mar 14, 2005 | 07:09 AM
FilthyRich's Avatar
rockware sells a bolt on swing out carrier for around 450. Given your two options, I would put it on the bumper. Keeps the rig from being top heavy and your truck is already tall. It would make it look huge. IMO. not bad, but you can make it look a bit cleaner. All it takes is more $$$$ LOL
Old Mar 14, 2005 | 07:42 AM
User 051420's Avatar
Have your under truck tire carrier hacked and lifted to match your 2" body lift, and throw that 35 under there. Like steve....
http://fastq.com/~sschaefer/body_lift.html
Old Mar 14, 2005 | 07:51 AM
Jonathan's Avatar
what do you think?
thanks
I wouldn't put it on top, i've heard that can make for a very tippy ride, especially off-road.
Old Mar 14, 2005 | 08:04 AM
HOJU's Avatar
Neil, Right now I can't put it under. The bumper doesn't give me the room, I can't even fit my 285 spare anymore let alone a 35. the bumper should also sit 1.5-2" closer in anyways...
Old Mar 14, 2005 | 08:51 AM
Robinhood150's Avatar
Let the air out of the spare to make it fit?
Old Mar 14, 2005 | 08:58 AM
HOJU's Avatar
I let ALL the air out Steve.... still didn't fit
Old Mar 14, 2005 | 12:15 PM
FilthyRich's Avatar
can you trim the back of the bumper at all for extra clearance??? would it even help?? Just trying to help
Old Mar 14, 2005 | 12:29 PM
HOJU's Avatar
I can't trim the bumper cause it's hitting on the hitch. I'd like to have it under there, but it just doesn't seem like it's going to happen. I can't fit it inside with my subs 'n' stuff. If it did go on a tire carrier, I've thought about doing something like a reserve gas tank where the old tire went.... just thinking out loud-
Old Mar 14, 2005 | 01:24 PM
yotaman's Avatar
Question
FilthyRich,
Does "rockware" have a website? If not do you have any contact information?
Old Mar 14, 2005 | 01:37 PM
02Runner's Avatar
Check out Steves bumpers,
Schaefer, Sonoran Steel
IMHO: thats the way to go.
Doug M.
BTW: Thats one helluva ride HOJU.
Old Mar 14, 2005 | 02:19 PM
HOJU's Avatar
Doug M.
so are you saying i should ditch my bumper and get a new one?
Yotaman, the Rockware website is www.rockware.net
Old Mar 14, 2005 | 02:28 PM
PoBoy's Avatar
Throw it on top. The amount of money you spend on a rear tire carier will never be recouped in gas savings. Keep a heavy duty plastic bag in the back...when you go wheeling, put the tire in the bag, then put it in the back seat...or build a new sub box that will allow you to put it in the rear on top of the box.
Old Mar 14, 2005 | 02:36 PM
yotaman's Avatar
HOJU,
Where did you get your front bumper?
Old Mar 14, 2005 | 03:49 PM
HOJU's Avatar
Originally Posted by yotaman
HOJU,
Mike at Xtremeoff-road
Old Mar 14, 2005 | 04:03 PM
dragr1's Avatar
Mine won't fit underneath either so it's on the roof. Not really tippy, but the gas mileage sucks.
Old Mar 14, 2005 | 04:37 PM
HOJU's Avatar
what mpg did you lose putting it up top? 1, 2, 3?
Old Mar 14, 2005 | 04:47 PM
calg3's Avatar
I'm not sure whatever happened with the idea, but a while back somebody proposed a spare tire carrier that would slide into a receiver hitch.
Also, if you want to make/fab your own tire carrier on your bumper-you can get the tire carrier spindle from Slee:
http://sleeoffroad.com/products/products_diy.htm
Old Mar 14, 2005 | 04:48 PM
epic37311's Avatar
https://www.yotatech.com/forums/f2/please-make-your-thread-topics-easy-read-understand-53802/
Old Mar 14, 2005 | 06:57 PM
dragr1's Avatar
Not sure, I don't drive it enough to keep check, but I would guess about 2. Around town you won't notice, the only place it will make a difference is highway trips.
