What gears should i do???
Old Mar 20, 2005 | 03:08 PM
97yotaman's Avatar
hey just wondering your guys opinions on what gears i should do for my 97 tacoma, i have a 3" suspension lift with 32x11.50 inch tires with a 15x10 rim, the truck goes alright around town but soon as i go on the highway its a slug, should i get gears?????? If so, what gear ratio should i get and how muhc would they cost?
Old Mar 20, 2005 | 03:18 PM
4Crawler's Avatar
General rule for gears is StockRatio * (NewTireDia/StockTireDia). Just as an example, assuming a 29" stock tire and 4.10 stock gears, 4.10*(32/29) = 4.52. A 4.56 ratio is the closest available ratio in that case:
http://www.4crawler.com/4x4/4R_TechI...tml#DiffRatios
Not saying that you had 29" stock stires nor that you have 4.10 gears, just using some numbers for an example.
Figure about $400-500/axle to regear assuming you pull the 3rds out at take them to a shop.
Old Mar 20, 2005 | 03:36 PM
dragr1's Avatar
Didn't some of the early Tacoma's come with 3.58 gears?
5spd or auto?
Old Mar 21, 2005 | 07:03 AM
97yotaman's Avatar
its a 5speed
Old Mar 21, 2005 | 07:09 AM
rimpainter.com's Avatar
I have 32's and went to 4.30's and was very happy with the results. My mileage dropped about .5MPG on average, but my "pep" came back. I had 4.10's.
Old Mar 21, 2005 | 04:07 PM
dragr1's Avatar
Originally Posted by 97yotaman
its a 5speed
If you plan on staying with 32's-I say this b/c everyone with 32's ends up with 33's, then go 4.30's for mostly highway driving or 4.56 for a good combination of offroad/onroad. If you plan on 33's in you near future, you may want to think about 4.88's.
Old Mar 21, 2005 | 04:23 PM
97yotaman's Avatar
when you put the 4.30's in how much did they run you and how much did it cost to put them in?
Old Mar 21, 2005 | 04:57 PM
I purchased a donor rig (96 4Runner with 4.30's and e-locker). I then swapped the front and rear axles out on both rigs, by myself, in 100-degree heat, with no air tools. I then sold the donor rig for $300 more than I bought it for.
I took a slightly different approach than most.
Old Mar 21, 2005 | 06:54 PM
dragr1's Avatar
Hehe, I did the same thing w/o the donor rig. I bought a complete front 4.30 diff and a complete 4.30 rear axle w/elocker and swapped them, but I had help.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
