22R-RE, How many Quarts of Oil?
Old Mar 17, 2005 | 09:36 AM
AKennedy87's Avatar
Question 22R-RE, How many Quarts of Oil?
How many quarts of oil am I supossed to use with the 22RE engine?
Old Mar 17, 2005 | 09:37 AM
AxleIke's Avatar
4.5 quarts
Old Mar 17, 2005 | 09:40 AM
Glenn's Avatar
I have always used 4.5 in mine.
Old Mar 17, 2005 | 11:18 AM
Yamaha+Toyota=Fun's Avatar
I use 4.5
Old Mar 17, 2005 | 11:33 AM
EWAYota's Avatar
4.5 quarts in mine too
Old Mar 17, 2005 | 01:55 PM
deathrunner's Avatar
4.5
I find it helpful to use an additive in a .5quart container, then you can easily add 4 quart sof oil. Just a thought.
Old Mar 17, 2005 | 02:09 PM
4Crawler's Avatar
From the Owner's Manual:
http://www.4crawler.com/4x4/4R_TechInfo.shtml#Fluids
4.9 qts. is the official volume, I usually use 4.5 then dump in the other 1/2 qt. then the level starts to get near the add mark.
Old Mar 17, 2005 | 07:25 PM
Why don't you just say that you put in 5?
I've never seen the 4.9 recommendation, but I believe you. Do you think us 4.5ers are causing harm?
Old Mar 17, 2005 | 08:09 PM
4Crawler's Avatar
The 4.9 figure is directly out of the '85 Owner's Manual from my 4Runner. I think that is a dry fill and I doubt you can drain every single drop from the engine. Better to underfill a little than to overfill. If I do 4.5 qts. it is close to the top mark on the dip stick. My engine uses some oil, so it is usually down to the add line by around 1500-2000 miles.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
calderp
Jul 27, 2015 09:58 AM
Coreyr384
Jul 10, 2015 11:13 AM
