Okay, I did the swap, need fine tuning help
Old Mar 21, 2005 | 05:05 AM
rmode's Avatar
A while back I posted about swapping the engine in my sons 96 Tacoma. It's 4WD/AT with the 3.8, and I'm swapping with the same motor. I had a little trouble at first because they had sent me a different year motor to start with so I sent it back and finally got what seemed like the right one. After the install I found that there was one small difference, a vacuum line coming out the side of the plenum. So I wound up switching the whole electrical harness out and using my original plenum. It runs great and evrything works as it should except for one thing, the high idle at start-up isn't working now. It makes it just a little hard to crank first thing or anytime it has been sitting a while but other than that everything is perfect. What am I missing or what can I do? I don't want to have to take it to the dreaded dealer if I don't have to. I figure if I got this far on my own hopefully I can get this last detail, but undoubtedly I need a little help!
Thanks for your responses,
rmode
Old Mar 21, 2005 | 05:11 AM
rmode's Avatar
I wrote 3.8 but meant 3.4
Sorry for the confusion, must be that two fingered typing!
rmode
Old Mar 21, 2005 | 05:13 AM
MTL_4runner's Avatar
rmode
Just to clarify, this is a 3.4L motor?
Edit: You might want to look at cleaning and testing your idle air control valve (IAC).
If it is stuck or not working that would cause the condition you mentioned.
Old Mar 21, 2005 | 05:19 AM
rmode's Avatar
Yes it's 3.4 as I stated in the follow-up post above. Don't know where my brain was at when I typed that. I think it's fried from the swap!
rmode
Old Mar 21, 2005 | 05:22 AM
Here's a picture of the throttle body and the idle air control valve (green thing on the underside of the throttle body at the bottom of the picture) that I lifted from a previous thread:
Jun 1, 2021 01:51 PM
A2theK
Jul 12, 2015 10:46 AM
nick b
Jul 11, 2015 04:38 AM
Kluch8651
Jul 9, 2015 10:39 AM
timmJ
Jul 7, 2015 02:01 PM
