Hurculined my 97 grill and limited flares (pics)
Old 03-20-2005, 03:15 PM
Hyperlite's Avatar
I Hurculined my 3rd Gen Limited flares and body cladding. I did the grill and my speaker box last week and was very satisfied with the results.
I just washed it in the pics so the flares are wet and the weather stripping is not installed. I'll take better pics tomarrow.
Old 03-20-2005, 03:23 PM
DudeBud's Avatar
looks good ........... how about some specs on that bronc
Old 03-20-2005, 07:16 PM
Hyperlite's Avatar
It is a 1969 Bronco Half Cab. It had a 170 6 cyl with a blown head when I bought it so the block/transmission is sitting in the woods so I am looking for a 351 windsor or a 5.0 HO EFI. I am the second owner and it has not run since 1989.
some stats.....
-5.5" superflex suspension
-3" body lift
-blue urathane bushings
-frame off restoration
-POR 15 (frame, axles, suspension)
-Ford 9" rear axle with trac lock differential 4.10 ratio
-Dana 20 transfer case
-33x12.50 BFG Mud on 15x10 amercan racing wanted 38.5 but the wheels and tires were only $100
Old 03-20-2005, 07:22 PM
DudeBud's Avatar
any pics for it i know this is a yota board but broncs are sweet. go with a early windsor or even better a stroker
Old 03-22-2005, 07:27 PM
Hyperlite's Avatar
I'll post some pics soon. It looks good but it's a project.
Old 03-22-2005, 07:36 PM
evilcow's Avatar
The grill and flares look great. I wanna do that to the grill on my wifes 97.
Old 03-22-2005, 07:43 PM
89macrunner's Avatar
whne you did your speaker box did you paint the wood or carpet or what did you do?...that would be nice and would hold up
Old 03-22-2005, 07:57 PM
96LtdYota's Avatar
that looks damn good
Old 03-26-2005, 12:32 PM
Hyperlite's Avatar
When I did my speaker box, I striped the carpet off I wanted to keep my box cause it was made by JL audio for the 12w6 and is 1" MDF. I had trouble getting the glue off so I used a dewalt metal grindig flap disc and grinded it to the smooth MDF surface (wood disc might have worked also). Then I panted it gloss black, sanded it till the gloss was gone and was roughed up, then I wiped it down with acetone. I hung it in a tree and then rolled 2 thick coats 1 hour apart and let it dry for 24 hours.
Old 03-26-2005, 02:14 PM
NorCalVP's Avatar
I put Herculiner on the front bumper of my taco and hated it... It's not very durable, so every time a rock hits it it flakes off. Also it faded really quick, Within 8 months, my bumper was a dull grey, not shiny black.... Plus it was a pain in the ass to get off (steel tube bumper that i made). Took me a whole day with a wire wheel. Now i just use gloss black spray paint, works 10 times better, and it's easier to repair.
Steve
Old 03-26-2005, 03:03 PM
ranma21's Avatar
That looks really nice. I plan to do the same thing on my runner too. I thought about lineX too, and the duplicolor spray on liner. WOnder which one is the easiest, most durable and economy way to go.
Old 03-26-2005, 03:10 PM
ranma21's Avatar
Did you spray it on or roll it on?
Old 03-26-2005, 08:53 PM
Hyperlite's Avatar
Here is some more pics. I think I am going to roll on another coat and finally do around my tag. Check out my new roll bar
I was waiting for the glue to dry on the side cladding, I was a little hard on it.
I need to put the weather stripping on but I don't know what type of adhesive to use?
06-01-2021 01:51 PM
nvdesertrunner
05-11-2020 08:18 PM
DeathCougar
04-01-2018 11:29 PM
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
09-04-2015 09:27 AM
Quick Reply: Hurculined my 97 grill and limited flares (pics)
