Transmission Solenoid problems
Old Mar 15, 2005 | 03:16 PM
toyotaoffroad91's Avatar
Exclamation Transmission Solenoid problems
Hey whats up guys. I read many of you post about solenoids. I replaced all of them becuase i was getting a code 62 for shift solenoid and 64 for a lockup. I replaced the solenoids from Transtec and now my truck stumbles and dies when i put it in drive. It also makes a horrible noise. have any of you had this problem. its a 22RE 4wd a340f auto tranny... PLEASE HELP!!
Old Mar 15, 2005 | 03:18 PM
note i have just ohmed put my old solenoids and they are all within specs, what else will cause this code to pop up.. occasonally the tranny slips and starts off in 3rd gear.
Old Mar 15, 2005 | 06:23 PM
ok i found out the problem.. The idoit (me) decided to put the lock up solenoid in place of the shift solenoid. the next question is what would cause a code 62 and 64 to keep comming up i jumped 12volts to each solenoid and the all work, the also read 13 ohms which is within specs. Does anyone have any ideas
Old Mar 15, 2005 | 06:53 PM
Robinhood150's Avatar
Wow, all in the span of 3 hours. Thanks for keeping this thread updated.
Old Mar 16, 2005 | 11:46 AM
ctcost's Avatar
I gather you cleared the computer by removing the battery cable for a minute or so?
Old Mar 16, 2005 | 04:34 PM
well i pulled the efi fuse to clear the codes does the same thing
Old Mar 16, 2005 | 11:00 PM
ctcost's Avatar
yup sure does. sheesh i wish i had an answer for you. Sounds like you did everything by the book. Good luck!
Old Mar 17, 2005 | 04:53 AM
MTL_4runner's Avatar
Follow the trouble shooting chart in this:
http://personal.utulsa.edu/~nathan-b...34electron.pdf
Old Mar 17, 2005 | 02:20 PM
ok problem solved. it turns out when the tranny got hot (fluid) the resistance in the solenoids jumped up way high. got all new solenoids from transtar for 140 bucks! truck acually feels like it has power and torque again.
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
jgwerth
Jul 16, 2015 03:23 PM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
