Another EGR Question
Old Mar 18, 2005 | 03:05 PM
jim628's Avatar
Hi:
There is a pipe that routes exhaust air from the engine exhaust area back to the EGR valve. When the engine is fully warm up and running at around 2000 RPM (but the car is not moving), should this pipe be warm since it routes exahaust air back to the vacuum manifold (controlled by EGR)?
If the pipe near the EGR valve is cold (not warm at all), is this normal? Or does it mean exhaust air is never recirculated back to the vacumm manifold?
Thanks,
97 4Runnter
4 Cylinder
Manual Transmission
Old Mar 19, 2005 | 07:45 PM
YotaJunky's Avatar
I was told by a friend who is a mechanic that the EGR valve should stay cool while the engine is running at idle just after starting. The EGR valve will open up after the engine warms up and get quite hot to the touch after you've driven it for a little while.
Old Mar 19, 2005 | 08:32 PM
cabbage's Avatar
Not a yota site but should be the same: click here
tj884Rdlx
Aug 28, 2015 12:04 PM
e_richard
Jul 30, 2015 06:50 PM
montanatruck
Jul 25, 2015 03:45 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
