trouble accessing U-joint zerk
Old Mar 16, 2005 | 12:05 PM
bktaco's Avatar
has anyone else here had a problem accessing the zirk behind the bolt on the u-joint (2000 tacoma xcab here)? its the rear-most zirk on the drive line (if i remember correctly). here's a picture of it: http://4x4wire.com/toyota/maintenanc...ble_cardan.jpg
just wondering if there's an easy way, or if i need to remove that bolt to get my gun on the zirk.
also, has anyone counted all the zirks? i counted 3 on the front drive line and 6 on the rear. ditto?
thanks in advance- bk
Old Mar 16, 2005 | 12:12 PM
hre814's Avatar
i don't have your model truck, but do you have a flexible hose attached to your grease gun or do you use the stiff end? i had to get a flexible hose to attach as it made greasing a lot better.
Old Mar 16, 2005 | 12:13 PM
bktaco's Avatar
i do have the flexible hose. but the tip is about 1 1/2 inches long, and i cant seem to be able to jam it in around that bolt...
Old Mar 16, 2005 | 12:16 PM
Marc's Avatar
On my 91 runner I find it easiest to jackup one wheel and turn the drive shaft until I can access all the zerks.
Old Mar 16, 2005 | 12:28 PM
leiniesred's Avatar
on my 89 front (double cardan) I have to turn the driveshaft just right to get it in there, but it will snap on and take grease.
Old Mar 16, 2005 | 03:22 PM
dave89144's Avatar
I use a mini grease gun that takes the small 3" tubes of grease. The head fits in there perfectly, but I need to hold it in there when pumping the handle.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Oct 2, 2015 07:47 AM
the_supernerd
Oct 1, 2015 09:20 PM
Matthew Perez
Sep 28, 2015 05:43 PM
Odin
Sep 24, 2015 04:38 AM
