Dash Repair (Pros & Cons)
Old Mar 17, 2005 | 08:53 AM
twosocks's Avatar
Have any of you had cracks in your dashes repaired? If so, were you satified with the results. I'm interested in hearing any pros or cons.
My 91 4Runner, that I just purchased in December, is in pristine shape but has a split in the dash, right above the center A/C vents.
Thank You
Old Mar 17, 2005 | 10:37 AM
gohawks's Avatar
the interior of my '88 is pristine except for the same thing...so i'd be interested in how some fixed this.
Old Mar 17, 2005 | 10:46 AM
Flamedx4's Avatar
Nope - plastic dashes do no lend themselves to repair. If you can even find someone who will do it, the results are not spectacular. Someone who is really good can generally make a decent repair but it will also usually return in a year or two as the original problem (drying and shrinking of the plastic) continues.
Old Mar 17, 2005 | 10:59 AM
Steveh29's Avatar
Here's what classic car restorers use. It's not cheap though.
http://www.justdashes.com/
Old Mar 17, 2005 | 01:33 PM
Flamedx4's Avatar
They can only do that with parts they have a mold for. No Toyotas listed.
Old Jul 23, 2010 | 10:33 AM
thinsley's Avatar
I'd use a dashcap, wait! I just ordered one, so I guess I AM gonna use the dashcap. It's ABS plastic and molded to fit. I'll be installing this weekend and will send pics. Although I think I did see a thread with pics on the board the other day. Why not use the dash cap?
Old Jul 23, 2010 | 10:38 AM
B4Runner's Avatar
I've been thinking for a while of trying something out. You know how the edges of the slit are higher than the rest of the dash. Well, obviously, you can't just push them back in. So, I think I'm going to try and just sand down the part that is sticking up until everything is level. (Yes, there will be a big crater in the dash now.) Then I'll find some plastic filler and fill it in. It probably won't be the prettiest of jobs or anything, and you will be able to tell it's a cheap patch job, but I'm pretty sure it will look better than how it did before repair.
Old Jul 25, 2010 | 04:14 AM
MarcBallz's Avatar
Know if ya have any fiberglass skills youd be better off patching it up like that and use some clamps an fans to dry. sand it all down an get it rino lined
Old Jul 25, 2010 | 07:07 AM
Evil.Dingo's Avatar
Heres mine, I went with the black unpainted abs dash cap.
Here is the link to the seller.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
__________________
Old Jul 25, 2010 | 07:44 AM
ET's Avatar
ET
2nd gen 4runner dashes are a foam type dash. not solid plastic. but i'd go with fiberglass repair like marc suggested or get some great stuff and squirt it in there. or just find a junkyard or check ebay for a replacement.
Old Jul 25, 2010 | 08:04 AM
justinmnhall's Avatar
that looks great! how is the fit?
Old Jul 25, 2010 | 08:21 AM
Evil.Dingo's Avatar
fit is perfect. The thing I liked was that where it mates up with the cluster cover is a little long when you get it so you can trim it too make it fit perffectly. All I used was sandpaper.
Old Jul 25, 2010 | 02:43 PM
Evil.Dingo's Avatar
http://cgi.ebay.com/ebaymotors/Toyot...item43a098c3cf
Jdgarrison
Oct 1, 2015 05:22 PM
matrad
Aug 8, 2015 03:00 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
msane99
Jul 27, 2015 06:14 PM
tpd143
Jul 7, 2015 09:06 AM
