Major repairs - what have you had to replace?
Old Mar 17, 2005 | 09:43 AM
HaveBlue's Avatar
I was just talking to a customer who is refinacing their truck to pay for repairs. $6,500 in repairs actually. It's a Ford PSD. According to the invoice, they had to replace the turbo, exhaust mainfold, MAF, and quite a few other things. This truck only has 75,000 miles on it. I got to thinking about how my 4Runner has 150,000 miles and has only had a few things fail.
So, what have you had to replace? These are items that have broken or failed.
So far, here's what I had to replace:
Starter
Spark Plug wires (Borg/Warner wires split after only 3,000 miles)
T-Case front output shaft seal
Swaybar end links
Power steering pump rebuilt
Axle seals
Those are the only things that have broken that I have had to replace. The list gets longer if I include regular maintenace items.
Post up!
Old Mar 17, 2005 | 09:51 AM
Mickdady's Avatar
Clutch at 95k miles
err - um thats it
Old Mar 17, 2005 | 09:52 AM
MTL_4runner's Avatar
For mine it has been nothing but regular maintenance stuff
EDIT: Ok I forgot I warped a set of rotors towing a boat, an O2 sensor and the AZ sun killed a battery on me.
Old Mar 17, 2005 | 10:10 AM
ugadawg95's Avatar
Same here just regular maintenance stuff...knock on wood.
Old Mar 17, 2005 | 10:12 AM
Glenn's Avatar
Starter, alternator, clutch ... wait, aren't those things that are usually replaced at some point? I guess nothing that wasn't a normal wear item.
Old Mar 17, 2005 | 10:23 AM
rimpainter.com's Avatar
Clutch. HG and rear coils/bumps (under campaign). Oh and warped rotors.
Now my starter is "starting" to show signs of taking a crap.
Old Mar 17, 2005 | 10:28 AM
NorCalVP's Avatar
Brakes (warped front rotors) and a clutch at 101K. As far as TSBs it's had the HG recall, and the rear springs.
I love my Toyota
lee's Avatar
lee
ditto
Old Mar 17, 2005 | 10:29 AM
bike4miles's Avatar
Warter pump, timing chain, air flow meter, O2sensor, Fule temp sensor, Clutch has alredy been replaced when I got it allong with full brake job, throttle body, Bumpers all around, grill, seats, tons of other little stuff.
Old Mar 17, 2005 | 10:47 AM
Yota4runner's Avatar
Brakes,alternator x2, battery x2, rear wiper motor,gas tank,exhuast, bumper ends. plus tonnes of other little junk.
Old Mar 17, 2005 | 11:00 AM
sswearin1's Avatar
just maintainence, timing belt, spark plugs, change oils, windshield cracked, and my starter sounds suspect. 2000 with 84.
Old Mar 17, 2005 | 11:07 AM
jacksonpt's Avatar
Senior Member
nothing that I would consider major.
110k miles on my rig, replaced the starter, rotors (a few times), battery, timing belt. Everything else is maintenance type stuff... though you could argue that those things are also maintenance issues.
Old Mar 17, 2005 | 11:17 AM
X-AWDriver's Avatar
Rear axle seals at 95k and that's it but it's begging for new shocks/springs and those are coming soon.
Old Mar 17, 2005 | 01:13 PM
4RUNR's Avatar
Guest
Passenger side stop tail light bulb.
It was major. I had to start a new thread on how to get the assembly off.
Old Mar 17, 2005 | 01:40 PM
RIPPER's Avatar
Just had the engine replaced for a cylinder that exploded at 3000 rpm. Engine had 98000 miles on it.
Old Mar 17, 2005 | 04:12 PM
SD70MAC's Avatar
Left front rotor, left rear wheel seal, right front locking hub, 2 solenoids in tranny, radiator, speedo cable, windshield washer tank (only because retard oil change person at walmart filled it with WATER in the middle of winter. BTW, NEVER GET YOUR OIL CHANGED AT WALMART!!!! ) What needs to be fixed: PS pump leak, rear main seal leak.
Old Mar 17, 2005 | 04:22 PM
maintanance like:
shocks (bushings wore out)
rotors (too warped for me)
Abuse:
rediff seal (probably my own fault for hitting it off road)
back bumper (idiot hit me)
repairs:
throttle body sensor
Starter maybe be acting up or the truck is just spending too much time in the sun and short drives these days
Old Mar 17, 2005 | 05:03 PM
91Toyota4x4's Avatar
Take out 3 screws. Pull old bulb out.
I kid, sorta.
Old Mar 17, 2005 | 05:25 PM
Silver_Truck's Avatar
plugs, wires, clutch, transmission (as soon as the lift is freed up), rebuild heads
Old Mar 17, 2005 | 05:39 PM
waskillywabbit's Avatar
Pick a part on the 85 and I've replaced it, had it replaced, fixed it, had it fixed or have it on the list to be fixed and/or replaced...
Are we having fun yet?
