Major repairs - what have you had to replace?
Old Mar 18, 2005 | 03:49 AM
gwhayduke's Avatar
I replaced the '89 Corolla with a '99 4Runner...geez was that expensive!
Old Mar 18, 2005 | 06:56 AM
Bumpin' Yota's Avatar
Originally Posted by HaveBlue
I was just talking to a customer who is refinacing their truck to pay for repairs. $6,500 in repairs actually. It's a Ford PSD. According to the invoice, they had to replace the turbo, exhaust mainfold, MAF, and quite a few other things. This truck only has 75,000 miles on it. I got to thinking about how my 4Runner has 150,000 miles and has only had a few things fail.
So, what have you had to replace? These are items that have broken or failed.
So far, here's what I had to replace:
Starter
Spark Plug wires (Borg/Warner wires split after only 3,000 miles)
T-Case front output shaft seal
Swaybar end links
Power steering pump rebuilt
Axle seals
Those are the only things that have broken that I have had to replace. The list gets longer if I include regular maintenace items.
Post up!
hmmm sounds like a 03-04 6.0L PSD.... At least the headgasket hasnt blown, like most of em have....oh wait I better not jinx him We've got an '05 PSD, it's a beast but Im waiting to pop the hood and see the coolant reservior spewing out coolant.....
oil lots of oil
oil filters
spark plugs
idler arm (gotta re-replace it)
shocks
rear axle seal
whole damn rearend
timing belts
water pump
spark plug wires
distributor cap
rotor
valve cover seals
radiator
thermostat
brakes
tires (4 or 5 sets now)
ALTERNATOR
and a few batteries (look at sig to see why...LOL 8.8kW)
im sure there is more but I cant seem to remember...
Old Mar 18, 2005 | 09:41 PM
Phisherman's Avatar
New engine at around 96k miles. The oil rings got lazy and hogged all the oil. They should be friends with Bush.
I backed into a tree at 120k and had to replace the ECU for some reason. I make up for that by keeping the factory brakes for 150k miles.
Old Mar 19, 2005 | 08:05 AM
User 051420's Avatar
Since I've owned it.....
Master Cylinder
Axle Seals
Wheel Cylinders
Brakes, Brakes, Brakes
T-Belt/Waterpump maint, etc....
Old Mar 21, 2005 | 05:10 PM
  #25
yotaman's Avatar
Talking
On my 1992 pickup with over 300,000 miles I’ve never did what I would call major repairs to it.
I’ve replaced the:
Head gasket x1
Clutch x2 (teaching people to drive a 5 speed can be expensive)
Alternator
and preformed all the regular stuff every some many miles
On my 1995 4Runner that has 230,000+ miles.
I replaced the following after I got it:
Cam and Crank Seals
Timing belt
Rear axle bearing and seals
Pinion seal
It needs the head gaskets replaced
CV-axle
Rotors and brake pads
Old Mar 21, 2005 | 05:14 PM
  #26
dibble9012's Avatar
when i first got it, rear axle seals, new brakes, new battery, thats it as far as major, everything else is just regular stuff
Old Mar 21, 2005 | 05:35 PM
  #27
junbug's Avatar
will be replacing the engine in a couple of days.
since i'm on the subject of engines, what would you guys choose from these options:
1) $1595 including installation, with $90 towing fee and 2-3 day turnaround time and a 2 year warranty.
OR
2) $1580 w/ $600 labor charge, free towing, 7-9 day turnaround time cuz theyre busy and a 5 year unlimited warranty.
Old Mar 22, 2005 | 05:56 AM
  #28
YotaJunky's Avatar
Since I've owned my rig, about 3 months ago:
replaced bushings in alternator
cleaned out starter
new distributor cap and rotor
new NGK plugs and wires
new air filter
new sway bar links and bushings
installed zerk fittings for steering knuckles
new rear brake cylinders
replaced front fenders, headlights, bulbs
replaced speedometer cable
flushed out rad, clutch and brake fluids
regular oil changes
replaced valve cover gaskets
replaced tie rod bushing
reinstalled right manual hub
Old Mar 22, 2005 | 09:29 PM
  #29
deathrunner's Avatar
Hubs
Starter
clutch
4 U joints
pinion seal
outer rear axle seals
shift knob
Battery
rear window lifting mechanism
rear window relay
rear window wiring
2 BJ's (that stands for Balljoints...I wish it didn't)
Old Mar 24, 2005 | 09:27 AM
  #30
DrummerDaveB's Avatar
92k miles
Replaced:
Front brakes & rotors, battery, tires, Plug wires, and other small maint items.
Needs:
Timing belt, axle seals, shocks (bought but still need installed).
Old Mar 24, 2005 | 11:06 AM
  #31
koyota93's Avatar
Engine
Old Mar 24, 2005 | 01:43 PM
  #32
ouch!
Old Mar 24, 2005 | 09:06 PM
  #33
87TurboYota's Avatar
I'll get back to you on this one. I'm still ordering parts and receiving parts after my timing chain broke.
Old May 4, 2005 | 10:49 AM
  #34
update: Starter died, and now I have coolant leak.
C
Old May 4, 2005 | 11:13 AM
  #35
calisurferdude2000's Avatar
Other than general maintenance, i've:
replaced all gaskets from the head up
had the head machined(it got warped) (still trying to figure out how that happened)
had the intake manifold machined(it got warped too)
new timing chain
new coil
new bed
new stereo(my pioneer that was to go in it was confiscated-"read stolen" by my gangsta wannabe punk good for nothing brother.
Old May 4, 2005 | 01:55 PM
  #36
ASU4runner's Avatar
Steering rack
timing belt
rotors
wheel cylinders
tie rods
O2 sensor
cv boots
All of these I've replaced myself and saved $1000's...
171,000 miles and counting
Old May 4, 2005 | 02:02 PM
  #37
kylerensmeyer's Avatar
starter... but only because my alarm reset or something and had a starter kill, so i thought the starter was gone... what a waste of $173...
other than that just regular maintanence.
Old May 4, 2005 | 02:09 PM
  #38
Steveh29's Avatar
The only high dollar item I've gone through is a transmission. The synchros went bad in my 5 speed at about 150K miles. Put in a rebuilt Marlin transmission and had no more problems.
Otherwise just normal stuff for a ten year old 4Runner with 183K miles on it:
Water pump at 150K miles
Rear axle seals and front wheel bearings at 115K miles
Tie rod ends and ball joints at 115K miles.
Shocks a couple of times
Brake pads a bunch of times
Spark plugs a bunch of times
Radiator at 130K miles (hoses twice).
Power Steering pump at 170K miles.
Three timing belts and of course the regular belts.
Two clutches
Front T-Case seal
The front bushings in the a-arms are going. That'll be my next project. I hear it's a pain! :cry:
Old May 5, 2005 | 02:13 AM
  #39
91 4Runner's Avatar
Rear window motor,Exhaust, O2 sensor, Fuel filler tube (was leaking) Plug wires,Cap & Rotor, Driverside CV axle, Driverside inner door handle, 2 U-joints, battery & terminals, too many antennas to count, and the big one....... drumroll please......... The A340H tranny... That one hurt....
As for what needs to be fixed - passanger side calliper, both pinion seals, rear tailgate (due to rust) drivers side fender and drivers door (combo rust/trail damage) plastic fan, swaybar end links, passenger side cv-boot or axle (depending on how long it takes to get around to it) Rad (she's getting a little thin), fan, rear heater lines, rear coils (saggy ass), driverside lower balljoint... And my next one...... Speedo cable (before I get a ticket for speeding) Probably more, but I cannot think of any right now...
Old May 5, 2005 | 02:45 AM
  #40
DMG's Avatar
DMG
I thought the psd had a factory 7year 100k warranty??
sandyota
Feb 4, 2021 11:16 AM
mdev126
Oct 4, 2015 04:48 AM
A2theK
Jul 12, 2015 10:46 AM
skoti89
Jul 6, 2015 07:45 PM
Jnkml
Jul 6, 2015 01:20 PM
