Help- Need Quick Advice With Stripped Head!!!!!!!
Old Mar 20, 2005 | 04:28 PM
84runner's Avatar
alright guys. My truck has a HUGE exhause leak so i take off my hood and see where it's coming from. Turns out TWO of the studs that hold my header to the head STRIPPED and FELL OUT.
So basically, the HEAD itself is stripped. The header is 1/4 of an inch from the head where those two studs should have been.
MY question is.
1. Will it hurt to drive my truck with that 1/4 inch gap in between the head and headers?
2. what should i do to fix this problem? Obviously machine shop, but will it be fixable with a helicoil or what??
CRAP. HELP!!!
thanks
Old Mar 20, 2005 | 04:37 PM
waskillywabbit's Avatar
Try searching the archives at Pirate and I think you'll find a quick answer.
good luck.
Old Mar 20, 2005 | 04:46 PM
jimbo74's Avatar
a machine shop can fix anything if they know what they are doing... most likely they will weld the hole shut and drill and tap it.....
Old Mar 20, 2005 | 04:50 PM
Yamaha+Toyota=Fun's Avatar
I wouldn't drive with the header leaking like that. Without the exhaust directed away from the motor, it could possible burn a valve.
Old Mar 20, 2005 | 04:53 PM
dwh91102's Avatar
are you for sure its stripped?
Old Mar 20, 2005 | 05:06 PM
84runner's Avatar
Yes. I'm SURE it is stripped. The damn stud came out with ALL the threads filled with metal(ie the head!).
What are the chances of burning a valve or doing damage??? I REALLY need this for work tomorrow, but if chances of damage are good, then i guess I'll find an alternative.
PLEASE helP!
Thanks for the fast replies fellas. I'm really greatfull.
Old Mar 20, 2005 | 07:00 PM
rugerm44's Avatar
Go get a helicoil kit.I think the sell them at napa.Its a threaded insert.Comes with the tool to install it.The average person can install one.Just read and follow the directions.
Old Mar 20, 2005 | 07:03 PM
jimbo74's Avatar
dont drive it like that, if its that bad, only bad things will happen.... you might not break anything, but do you really want to take that chance?
Old Mar 20, 2005 | 07:05 PM
84runner's Avatar
ok.
What size/thread helicoil kit do i get?
thanks!
Colington
Mar 8, 2020 09:51 AM
jasonty
41
Dec 23, 2018 01:00 PM
pyramid
Jul 30, 2015 10:05 AM
yourrealdad
Jul 21, 2015 11:13 AM
Coreyr384
Jul 10, 2015 11:13 AM
