radiator leak 1999 V6
Old Aug 27, 2011 | 05:09 AM
85CCT's Avatar
Ok. I haven't posted on here in a long time. I have a 1999 Tacoma V6 that has a coolant leak at the trans cooler fitting on the passenger side. The fitting is a threaded pc with a nut and large washer against the radiator. The antifreeze is dripping right at the washer. I've read on here about trans cooler problems and the "milkshake" thing (oooh, that gives me chills just thinking about it). Can this fitting be replaced or is it a good idea just to replace the radiator? The truck has 210,000 miles on it, but I don't know if it is the original radiator.
Old Aug 27, 2011 | 05:33 AM
waskillywabbit's Avatar
Replace radiator.
:wabbit2:
Old Aug 27, 2011 | 06:09 AM
KZN185W's Avatar
Yes, replace the radiator would be the solution
Old Aug 27, 2011 | 07:06 AM
mwc0404's Avatar
Replace it! you can get a pretty good one online for not to much money, just make you get one with the built in trans cooler or get a separate trans cooler, im running a hayden trans cooler on my 99
Old Aug 27, 2011 | 07:58 AM
tunnelmotor99's Avatar
Replace the radiator, bypass the integrated cooler with an auxiliary one.
Old Aug 27, 2011 | 08:03 AM
mwc0404's Avatar
Yeah my hayden pro trans cooler works so much better than the built in one, thats why when i replaced my radiator i ordered one without the trans cooler, ive got got my trans cooler positioned at 70%
Old Aug 27, 2011 | 08:34 AM
85CCT's Avatar
Thanks. I'll probably replace it with one with the trans cooler. I read on the forum that the external trans coolers may not be the best in colder winter climates.
Also, do you guys prefer the metal radiator from "radiator barn" or others from parts stores?
Old Aug 27, 2011 | 12:43 PM
jimig's Avatar
http://www.car-stuff.com/carparts/to...tings+Page%3A8
Just get another denso one and be done with it. Chances are, you'll never replace it again.
Old Aug 27, 2011 | 03:28 PM
85CCT's Avatar
Thanks all. And jimig that's a good price, thanks.
Old Aug 28, 2011 | 06:16 AM
smokey0066's Avatar
My radiator was about to do the same thing. You can take a look at the photos I posted here. Replace that radiator!
Road Bull
Oct 10, 2015 04:55 PM
TJWilly
Jul 31, 2015 02:05 PM
yourrealdad
Jul 21, 2015 11:13 AM
Avenged
Jul 9, 2015 07:55 AM
cyclist231
Jul 7, 2015 12:56 PM
