Transmission drain plug stripped
Old Jul 6, 2011 | 06:36 AM
BigBen's Avatar
The other day, I went to change my trans fluid and one i started cranking on the drain bolt i noticed it just spun... it didn't loosen or tighten, just spun. I searched online and found if you use a flat head screw driver as a lever to put pressure on the screw while you are wrenching it out the pressure will help it bight on the threads. Well, like an idiot i did this and only got it about 1/4 out Now i'm just leaking tranny fluid. I searched all the toyota truck dismantlers for a used tranny pan but to no avail. Anyone know where i can get one from? (besides the dealership). Or any other suggestions on how to fix this problem?
Thanks in advance ya'll
Old Jul 6, 2011 | 06:44 AM
waskillywabbit's Avatar
Get a pan off a toasted tranny. Shouldn't be that hard to find.
I scrapped one last month.
:wabbit2:
Old Jul 6, 2011 | 07:04 AM
blake.nemitz's Avatar
or cut it out and add a new bung
Old Jul 6, 2011 | 07:40 AM
87 'runner boosted's Avatar
ya, theres lots of used trans at scrap yards you could find, if not, plenty of repair options...could drill it out and tap to a bigger plug if needed...
Old Jul 6, 2011 | 08:41 AM
Asuarez737's Avatar
just tap the tranny pan and dye the bolt if it doesnt fit then get another bolt from your local hardware store
Old Jul 6, 2011 | 10:49 AM
quicksilvr's Avatar
I had to fix this problem on a '97 once. I ended up drilling out the old bolt, tapping the pan, and using a new oversize bolt with a GM style rubber covered washer. WARNING: After the drilling and the tapping, use a magnet to grab all the metal crap that's right inside the hole of the pan. I cleaned mine real good, and got a decent amount of shavings out. Then after driving about 50 miles, I also went ahead and drained and refilled the trans fluid again.
Old Jul 6, 2011 | 05:09 PM
BigBen's Avatar
Thanks for all the input guys. I emailed a couple salvage yards around here about blown trannies and pans, but I think i'm gonna try to tap and drill it first and if that doesn't work then i'll put some more effort into finding another pan. Any suggestions on how to tap the pan? I don't have any experience doing this, but i'm betting it can't be too hard and somewhat self explanatory right?
Old Jul 6, 2011 | 05:57 PM
Asuarez737's Avatar
Basically just find the rite size and youre done
Old Jul 8, 2011 | 03:03 AM
offset442's Avatar
fyi, what ever you decide to do take the pan off of the trans to work on it, the idea of repairing the pan while attached to the trans is not very smart, I would go with drilling and tapping in a bigger drain plug, but its not easy to do a good job of that while upside down taking metal shavings to the face............
smthwsn357
May 1, 2024 07:28 AM
pyramid
Jul 30, 2015 10:05 AM
kcaudill
Jul 20, 2015 12:06 PM
daddio
Jul 18, 2015 10:20 AM
jjrbus
Jul 17, 2015 07:06 AM
