150k miles - Getting valve cover gaskets - what else?
Old Jul 29, 2011 | 03:58 AM
DrummerDaveB's Avatar
Im getting my valve cover gaskets replaced as I've got some leakage around the covers.
Since it is apart, I would like to get anything else done that might need done.
So Im getting some new (er, reconditioned, cleaned and flow-tested) injectors for it at the same time.
Which new gaskets should I get besides just the valve cover gaskets?
PCV if it needs it obviously.
Anything else that I would do well to replace?
Old Jul 29, 2011 | 04:02 AM
waskillywabbit's Avatar
Really depends on what other maintenance you've done previously.
Plugs, wires, tstat, water pump, timing belt, pcv, spark plug seals, belts, hoses, fluid changes, etc.
:wabbit2:
Old Jul 29, 2011 | 05:05 AM
93toyrunner2's Avatar
Fuel Rail gaskets.
Old Jul 29, 2011 | 06:48 AM
:wabbit2:
Plugs and wires are good. WP and TB are good. PCV I'll probably replace the gasket around that. Belts . . not sure.
I was thinking of having the rad hoses replaced. Other fluids should be good.
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Jul 9, 2015 02:12 PM
Gamble_STi
Jul 7, 2015 07:54 PM
Vargntucson
Jul 4, 2015 12:15 PM
