Transfercase shifter gasket
Old Aug 17, 2011 | 08:20 AM
Kieffer1987's Avatar
My transfercase has been leaking from what appeared to be the front driveshaft seal (and the chain housing seal), however after doing a bit more reading, it appears the fluid might actually be coming from the top from the shifter gasket.
I'm almost 99% positive this is the case (but havn't torn out the center counsel to confirm) however everyone adds RTV to the pre-existing gaskets (which I have always thought was a nono) and then they seem to still have the leaking problem but no one has ever followed up on whether or not they have stopped the leak.
I have a 99 LTD, do I buy a new gasket from the stealership, or ditch the gasket all together and use RTV or the toyota Orange stuff?
Old Aug 17, 2011 | 09:01 AM
smokey0066's Avatar
I've never worked on my transfercase but what about the Toyota FIPG stuff. I've seen alot of that being used in shops.
Old Aug 17, 2011 | 09:35 AM
^ That's what I was thinking of. I've seen several threads both here and on other forums of people putting this on the existing paper gaskets, then it leaks. But no one has actually followed up as to whether or not they fixed the leak by just using FIPG or buying a new gasket from the stealership.
Last edited by waskillywabbit; Aug 17, 2011 at 10:17 AM. Reason: Inappropriate language assumed a typo
Old Aug 17, 2011 | 10:51 AM
Qyota's Avatar
I had to use RTV on mine, and it fixed the leak. I used a new gasket first, but that didn't stop the leak.
Old Aug 18, 2011 | 11:24 AM
Did you reuse the metal piece in between the 2 original gaskets or ditch the metal piece and just use 1 RTV gasket?
Jcrawl94
10
Oct 24, 2015 04:34 PM
Motomonty
Aug 9, 2015 05:53 PM
Tonetrk
Aug 3, 2015 08:47 PM
scottyg486
Jul 19, 2015 05:34 PM
Iceman4193
Jul 15, 2015 04:48 PM
