Wipers turn on when it rains/washer fluid no longer comes out
I have a 1997 Toyota Tacoma-v6-ext cab-4wd. My wipers(intermit) work just fine when it is dry out, all settings/timings work. When it snows/rains it will turn my wipers on to medium speed. I cannot turn them off or change speeds. I have no control over them after that. I am thinking it is a short/grounding issue/open wire or does something need replaced? Also my washer fluid no longer works. Has fluid, no leaks, good hoses/lines. What is the best checklist to follow to see what the problem is without replacing part after part. Thank you very much
jasonty
41
12-23-2018 01:00 PM
rushw
07-18-2015 01:46 PM
