Wierd Lights... suggestions anyone???
Old Oct 2, 2005 | 12:09 PM
Avsfreak1234's Avatar
Unhappy Wierd Lights... suggestions anyone???
Ok guys, I just installed a K&N FIPK (Cold Air Intake) on my Taco. Now that everything is put together my truck wont start. instead whenever I open the door it gives me the warning beeps and all of the dash lights, passangerside front and driverside rear turn signals all flash. I didnt mess with any of the electrical except disconecting the battery like you are suposed to do, and the mass airflow connections so you can work with the air boxes.
Has this happened to anyone? or does anyone have any ideas? thanks
Old Oct 2, 2005 | 01:36 PM
ebelen1's Avatar
I have an FIPK in my '99 4runner and have not had similar issues. Good luck in figuring this out. I'm sure someone with more info will chime in.
Old Oct 2, 2005 | 05:37 PM
LOCKnGO's Avatar
You tripped the anti-theft?
Old Oct 2, 2005 | 05:39 PM
Localmotion's Avatar
that would i would bet my marbles on. Maybe there is a bad connection on your battery terminals?
Old Oct 3, 2005 | 05:28 PM
ok guys. good try. I know it isnt the anti-theft because my truck doesnt have one. and I took your suggestion and checked out the battery terminals. they're fine. this isnt your run-of-the mill electrical problem. :pat:
Old Oct 4, 2005 | 10:47 AM
surf4runner's Avatar
ditto for my 02. look around for a disconnected/broken wire, some of those small gauge wires can break easily when mishandled.
Old Oct 6, 2005 | 05:44 PM
shovelhead's Avatar
look for a loose ground wire
Old Oct 7, 2005 | 03:23 AM
jc1kz's Avatar
Take the vin and call or check with you local dealer, the only reason for the lights to flash on and off and the beeps etc is that you have the anti-theift system on your trk....by disconnecting the battry you reset it and now you need the remote to reset....is this a new or used trk? also look all under the dash etc to see if you can find the valet switch.......on certain toyotas the factory alarm can be disabled by inserting the key and turning it to the on position then flipping the valet switch, then starting the trk... I know you say you don't have an alarm ....but your symtoms are that of a trk with the factory ......good luck......
primordialbeast117
Dec 19, 2015 12:23 PM
Iceman4193
Oct 16, 2015 10:50 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
the_supernerd
Oct 1, 2015 09:20 PM
Scotttekoch
Sep 28, 2015 10:30 PM
