Tight/hard e-brake lever
Old Oct 11, 2005 | 12:13 PM
nees1212's Avatar
Question Tight/hard e-brake lever
I've got a 97 automatic, and the e-brake lever is extremely hard to pull up. It only clicks maybe 3 times, and it doesn't brake well. I pulled over on a side road on a small incline, put it in neutral, and pulled the e-brake lever. The 4Runner rolled slowly. I've searched and found ways to tighten the lever, but this thing needs loosened at the lever, but tighter at the brakes. What can I do to adjust this?
Old Oct 11, 2005 | 12:19 PM
jimbo74's Avatar
check the condition of your rear brakes to begin with, something isnt working right
Old Oct 11, 2005 | 01:24 PM
Bob_98SR5's Avatar
remove the center console so you expose the ebrake mechanism. there are two opposing nuts on the ebrake. you will have to loosen the top one (upwards) and then tighten the lower one against it (again, upwards). this will relieve the tension. i believe your ebrake should have about 8 - 10 clicks before firmly catching.
bob
Old Oct 11, 2005 | 01:40 PM
nees1212's Avatar
Thanks guys. I will be looking at all the brakes here soon. I just got it, and I haven't had much time to check everything. However, the braking on the ride home was fine. There wasn't any vibration while stopping, and it seemed to stop fairly easily. I will remove the center console and look. I've adjusted my Tacoma before, but that's a different application.
Old Oct 11, 2005 | 01:45 PM
Bob_98SR5's Avatar
empty your center console storage thing and there are two bolts there. i think 10mm. at the front of the cc, there are two philips screws. remove those and then the whole she bang will come off
bob
Old Oct 11, 2005 | 01:47 PM
nees1212's Avatar
bob
Thanks again. I'll give that a try.
kawazx636
Oct 6, 2021 03:03 PM
okamikai
Apr 30, 2018 10:19 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Jason4X4
Sep 17, 2015 08:02 AM
JAmdor3
Aug 11, 2015 10:53 AM
