Indicator issues
Old Oct 10, 2005 | 01:24 PM
philtw's Avatar
Indicator issues
Having probs with my surf indicators, any common issues ?
Old Oct 10, 2005 | 01:46 PM
Flamedx4's Avatar
Surf indicators? As in wave height and period, as in Surf's Up - Kawabunga!
Old Oct 10, 2005 | 06:10 PM
Nic's Avatar
Nic
Phil, I assume you mean your turn signals are not working correctly. If so, could you describe your problem?
If it is a turn signal problem, the most common culprit is a bulb.
Old Oct 11, 2005 | 08:27 AM
philtw's Avatar
The left and right indicator do not seem to operate, when the indicator stalk is turned to the left or right there is a relay under the dash which clicks on an off, but there is no power to either lights, is there another relay driving the power on and off ? all the lights work perfectly as the alarm operates these with no problem.
Old Oct 11, 2005 | 11:22 AM
philtw's Avatar
okay I think I have tracked this down to a bad earth on th right hand indicators, I 'm struggling to find any faults, any help or ideas would be welcome ?
Old Oct 11, 2005 | 03:45 PM
Nic's Avatar
Nic
Phil, all I can do is offer you encouragement. More than likely the problem is something very simple. I mentioned bulbs earlier. Every time I have had problems with my signals (indicators), it was a bulb. My truck signals were giving me problems a while back-it turned out to be just a bad bulb, even though the bulb was not burned out. I don't know why. As foolish as it sounds, you may want to try that. As already said, I'm betting its something simple.
Old Oct 11, 2005 | 09:57 PM
philtw's Avatar
Nic, Thanks for the encoruagement I wil try that this morning, Ihave also got some ideas fromth OZ website, - someone else having problems with crazy indicators.
http://www.toyotasurf.asn.au/forum/viewtopic.php?t=5884
Old Oct 12, 2005 | 05:32 AM
Adam F's Avatar
Yup, try the simple things first. I was working on a truck at work where the fuse would blow when you turned on the left turn signal. it would flash a few times, and then blow. replaced the bulb and all was good.
nvdesertrunner
May 11, 2020 08:18 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
ddg71
Jul 24, 2015 01:24 PM
shisha1999
Jul 13, 2015 11:09 PM
