3zve fast idle problem
Old Oct 7, 2005 | 11:22 AM
Platypus1's Avatar
Hey all, my truck is idling at around 1600 - 1700 rpm. The only thing that has changed is that the weather is cooler now. i dont know if that has anything to do with it or not. i cant find anything wrong under the hood, and no check engine light has come on. Any ideas? How can I lower the idle?
Old Oct 7, 2005 | 11:37 AM
snap-on's Avatar
There is an idle up (valve?) switch? thingie! (yes thats a technical term) that bumps up the idle when the truck is cold in order to warm it up quicker. After it warms up that "thingie" should "let go" and it should go back to normal.
Id check that thinige, (vacume switch, relay bla bla bla) that controls that. SOunds like its not disengageing.
Old Oct 7, 2005 | 11:42 AM
Platypus1's Avatar
Do u know where its at?
Old Oct 7, 2005 | 11:53 AM
snap-on's Avatar
sorry that lame description but that is the best i can do.
Old Oct 7, 2005 | 12:19 PM
whays's Avatar
Does your truck idle up and stay up, or does it idle up and down back and forth.
The idle "thingy" is inside the throttle body. It is controlled by the temperature of the coolant that goes through it. If your truck is low on coolant, air will get inside the throttle body and the idle will get weird. You also might want to check and make sure the throttle plate is all the way closed.
Later.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
