Is this a symptom of shot/bad shocks?
Old Oct 3, 2005 | 08:26 AM
Godzilla's Avatar
when i hit a series of bumps, my rear end starts to move to a side like there is no contact between the road and vehicle. the shocks are stock and there is about 60k miles on my 99 4Runner Limited. If not shocks then what else could it be?
Old Oct 3, 2005 | 08:44 AM
Cape yota's Avatar
Sounds like a symptom of worn shocks to me. With 60k miles on the stock shocks it does seem reasonable to assume that they are worn and may need replacing. Does it look like they're leaking?
Old Oct 3, 2005 | 09:16 AM
Godzilla's Avatar
no leaking from what ive seen. just couldnt figure out if it is shocks or just cause the rear end is light.
Old Oct 13, 2005 | 07:41 PM
22re-efer's Avatar
My '96 does the same thing over washboard on the Forest service roads. I have Monroe Reflex on the back end, and it doesn't make much difference. It's the nature of the beast: solid axle and coils. Try airing down your tires or slowing down. That's the only things I've found that helped.
Old Oct 14, 2005 | 06:09 AM
MTL_4runner's Avatar
Jump off your rear bumper....if it rebounds and returns to rest right after, likely the shocks are fine.
The 4runner does have a light rear end so it can feel like it skips around when going over bumps.
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
beltcutter
Sep 30, 2015 06:14 AM
