Question about steering gearbox
Old Oct 9, 2005 | 10:25 AM
Lunnzz's Avatar
I was wanting to know will a power steering gearbox off a 1988 4wd PU with IFS work on a 1991 4wd PU with IFS?
Old Oct 9, 2005 | 10:51 AM
superjoe83's Avatar
yes, they are the same from '86-'95
Old Oct 9, 2005 | 11:55 AM
Lunnzz's Avatar
Thank you..
Old Oct 9, 2005 | 03:30 PM
squishy321's Avatar
What you may want to try if all the bolts are hard to get at and rusted like mine were is just take the gear shaft out of the 2 gearboxes takes 5 mins as compared to the 2 days it would have taken me to get the gearbox out. BUT i took a shaft out of a 89 runner and tried to put it in my 93 and voila the two shafts were different (same in every way cept one had 3 teeth the other 4). So what i did was just find a junked 93 runner and got the shaft out of that. I dunno if the 91 has 4 teeth or not, the 88 does but the 91 might have 3 like mine. Its worth it to check just to save the trouble. If you do got this route you have to remove the 3 bolts holding it to the chasis, and you have to play around with it to get it back in. Will require a hammer and it only goes in one way right, other ways and you get like 1 turn in your steering wheel. Just try seating the teeth in in different posisitions. Just a little tip in case you wanna try this, but it might not be compatible.
Old Oct 9, 2005 | 07:27 PM
fredtheturd's Avatar
I wouldn't try goofing with any of those shafts unless you know what you're doing. I tried doing what Squishy said up above a couple years ago. I got the shafts swapped, the whole thing put back together, cranked up the truck & my steering wheel did circles without a single movement in the front end except for the steering shaft. I just bought the $399 lifetime replacement sucker from Allpro Offroad. Haven't had any problems since I got it a year ago.
FRED!
Old Oct 10, 2005 | 10:12 AM
squishy321's Avatar
I wasnt too keen about fooling around with it either, but a trusty toyota mech had done it before and told me what to do. I would not by any means jury rig something up for something as important as steering. But what i was trying to say is if you have the exact same gearboxes and getting it off the truck is a big job ( I would have had to remove my radiator and fabricate new lines) then replacing the shafts will work and save you a lot of trouble. But if you box comes off easily then by all means replace the box.
glowz825
Jan 25, 2022 09:28 AM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
gillesdetrail
Aug 3, 2015 04:43 PM
bobpat
Aug 1, 2015 09:25 PM
