4wd operation
Old Oct 11, 2005 | 12:06 PM
TSB's Avatar
TSB
4wd operation
If I lock the hubs on a 1994 Toyota pickup before I start driving the truck. can I then engage 4wd at any time and at any speed? That's the way it worked on my scout. If it was snowing out I would lock in the hubs before I left and I could engage the 4wd anytime I needed to up to 50 MPH. Someone told me you had to stop the Toyota everytime you wanted to engage 4wd even if the hubs were locked. Is that true? Is that true for the tacomas with manual hubs? I'm thinking about purchasing a toyota truck but I want manual hubs and the ability to engage 4wd while the truck is moving and the hubs are locked.
Thanks
Tobin
Old Oct 11, 2005 | 12:09 PM
EWAYota's Avatar
yes you can shift into 4 wheel drive if the hubs are locked while driving, just dont shift into 4L while going over 5mph.
Old Oct 11, 2005 | 01:48 PM
Glenn's Avatar
Yes, that is no problem.
Old Oct 11, 2005 | 01:53 PM
Flamedx4's Avatar
Take note that there are different setups on different models.
There's ADD, manual hubs, auto hubs, (and AWD but we don't mention it around here...)
But all can be shifted to and from 4hi on the fly (with manual hubs too assuming they are already locked in.) The sweet setup is ADD *and* manual hubs. Best of both worlds.
Old Oct 12, 2005 | 06:43 AM
TSB's Avatar
TSB
Thanks I thought it would be a little odd if it couldn't do it.
Thanks
Tobin
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
mtrdrms
Sep 26, 2015 07:12 AM
Tcsdef
Sep 7, 2015 11:17 PM
May-39
Sep 6, 2015 01:05 PM
