leaking rear main seal
Old Oct 2, 2005 | 06:27 AM
hill's Avatar
can someone explain to me whats happening when the mechanic says to me i have a leaking rear main seal.
cheeers
Old Oct 2, 2005 | 06:34 AM
callmej75's Avatar
Its the seal at the rear of the motor that goes around your crankshaft. I'm changing mine right now...but with the motor out.
Old Oct 2, 2005 | 06:41 AM
keisur's Avatar
When is leaks, depending on how bad, it'll get all over in the bell housing and if you have a manual tranny your clutch will get saturated fast. The seal holds the oil in the engine around the crankshaft like callmej said.
Old Oct 2, 2005 | 08:23 AM
hill's Avatar
i just had my clutch repaired....and the rear main seal....
so the mechanic ˟˟˟˟˟ed something up when he put it back together????
So i should watch my oil level till i get it reparied? or tranny fluid?
CH
Old Oct 2, 2005 | 08:47 AM
callmej75's Avatar
Tranny fluid shouldn't leak...just watch the oil level. I'd be making a trip back to the mechanic and say WTF!
Old Oct 2, 2005 | 09:36 AM
kyle_22r's Avatar
yep, a properly installed rear main shouldn't leak for many, many years. maybe your mechanic should've put a sleeve over the crankshaft, as the seal will wear a groove in over time and lose effectiveness.
Old Oct 2, 2005 | 10:26 PM
keisur's Avatar
yea, oil level. Also watch that your clutch isn't slipping. If it is you need to get that seal changed ASAP or you'll be needing a new clutch as well. Me and 96LtdYota did my clutch back in March. I had a rear main seal in case it was leaking but it wasn't so I left it alone. I was afraid I'd not get the new one in good and it would leak. I'll pull it apart and replace it if it leaks later but I figured not to touch it.
I'd take it back to the mech that did the work and let him know there's a prob.
jerusry
Oct 19, 2015 05:28 PM
andrewtexas123
Jul 14, 2015 04:29 AM
jakebarrett
Jul 10, 2015 07:15 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
