97 Tacoma transfer case
Old Jun 11, 2010 | 06:29 AM
SHREK85's Avatar
Hi guys. New here, first post.
I have a 97 tacoma, 4x4, 2.7, 5-speed manual. It has a little over 204,000 on the ticker.
My front and rear transfer case seals are leaking and the front output shaft bearing is probably bad. I have tried searching a few other forums and talked to several toyota mechanics for info on replacing these items and no-one has seem to have taken one apart.
My questions to you guys are:
1) Has anyone ever had this problem?
2) Has anyone done this?
3) How hard is it to do?
My father is a mechanic and I have some mechanical knowledge. I have another vehichle ( new to me 85 4runner ) so down time is not a problem. Thanks for any information guys.
Old Jun 11, 2010 | 07:26 AM
scuba's Avatar
It is a common problem. If there is still oil in there its doubtful you have a bearing problem.
1. I personally have not but have read lots about it.
2. No
3. Other experiences say 20-30 mins if you can turn a wrench
Read this thread. http://www.ttora.com/forum/showthread.php?t=39302
Then download the FSM for your year : http://www.ncttora.com/FSM/1996/96_r...searchable.pdf
Or have a look at the online FSM for the 01-04 (most everything is the same) http://www.ncttora.com/FSM/2003/index.html
Good luck.
Old Jun 11, 2010 | 08:56 AM
SHREK85's Avatar
Thanks for the info scuba, more than I have found anywhere else.
Old Jun 11, 2010 | 09:36 AM
Kiroshu's Avatar
Most people don't "fix or repair" T-cases. They over look it and ignore it... If theres something wrong with a t-case its usually "Remove/Replace"
But if you know how to do it or can get a good manual its not a bad job to change those seals and keep riding. While you are at it i would change the fluid and be sure not to over fill or you will blow out those seals again.
Old Jun 11, 2010 | 10:40 AM
SHREK85's Avatar
Scuba hooked me up on some great reference material.
I plan on dropping the case anyway so draining and changing the fluid will not be a problem.
Dont think I ever over filled it, but I did buy it used so the PO could have done it.
I also never ran it dry either, but when I engage the case ( hubs locked or not ) I get a nice growl. This is the only reason I think the bearing is bad.
Old Jun 11, 2010 | 01:25 PM
scuba's Avatar
Yup !
Most people as in, y'all with older trucks ?
Your statement sounds like, I'm going to replace all the drywall in my house because 1 portion has a crack/hole.. or what have you..
If the transfer case still works, why replace it ?
Old Jun 11, 2010 | 01:35 PM
Kiroshu's Avatar
Well i was talking about if it was not working. Just general talk.(I go to typing and well... Stopping is hard) Like i said personally i would fix and or change the seals. And dry wall in a house is alot differnet then a 4wd transfer case in a Toyota truck.
Old Aug 2, 2010 | 02:17 PM
litterfisher's Avatar
A few of my trucks have had leaking transfer cases and its a pain to find good refurbished units. any one got any suggestions other than junkyards?
4x4-runner
Dec 27, 2016 01:58 PM
rednecktoyotahunter
Nov 18, 2015 08:58 AM
Chumlee780
Nov 13, 2015 03:18 PM
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
